Old 09-03-2010, 12:27 AM
idkfa idkfa is offline
Rep: 31 Posts: 205
Forward swept keels
Funnily enough I'm contemplating a forward swept keel! (twin rudders too but no canard)
Will get someone with the know how to crunch some numbers, but can you generalize as to whether or not it was beneficial, will you do so again? thanks.
Old 09-03-2010, 12:52 AM
Alik's Avatar
Alik Alik is offline
Rep: 1020 Posts: 1,893
The problem with forward swept keel was: the foil should be very rigid, otherwise it is twisting.
Old 09-03-2010, 12:55 AM
stubby's Avatar
stubby stubby is offline
Rep: 15 Posts: 55
Sunkel-Lozell Boat Design
Old 09-03-2010, 06:38 AM
rapscallion rapscallion is offline
Rep: 97 Posts: 356
Alik, How would the Pluto 800 compare to the Phuket Sports 8 in terms of speed?
http://janetcg32.blogspot.com
Old 09-03-2010, 06:46 AM
Alik's Avatar
Less weight is more speed; generally nothing else
Pluto800 is heavier (1200kg vs 850kg) and designed in 2000 for different Rules, where 1200kg was the lower limit.
As I remember, on Phuket8 there are bolted wings 2.45>3.03m; so total RM is higher as well.
Old 09-06-2010, 08:05 AM
Rep: 97 Posts: 356
Alik,
How difficult would it be to take the hull design of the K800, and put a higher performance rig and keel on the boat?
Like say, a rig with:
Main - 25.6 sqm
Jib - 16.0 sqm
Spinnaker - 94.0 sqm.
and a bulb keel with an 2.5 meter draft?
Old 09-06-2010, 10:34 AM
Alik's Avatar
Alik,
Main - 25.6 sqm
Jib - 16.0 sqm
Can be done, but any sence?
Structure has to be revised.
Old 09-09-2010, 06:53 AM
Rep: 97 Posts: 356
Originally Posted by Paul B View Post
Try talking to Paul Bieker.
He has a full on 27 footer (currently not for wood, but maybe could be modified in the construction plan) and the Shilshoal 27 (for wood construction) that has some accomodation.
http://biekerboats.com/Bieker_Boats/New.html
where does one find carbon/nomex developable panels?
I like the updated thunderbird..
Old 09-09-2010, 02:02 PM
Paul B Paul B is offline
Rep: 6 Posts: 1,696
I believe Bieker has a local source (local to him in WA State) who can provide the flat panels, pre-cut and ready to assemble.
DIY job?! Bullterrier Fiberglass and Composite Boat Building 5 05-12-2010 06:28 AM
advice design of a carbon fibre sportboat mast JorgenBeyer Sailboats 0 01-25-2010 07:32 AM
Trailerable sportboat weekender? Steam Flyer Sailboats 48 08-12-2009 05:12 PM
nicest throttles / shifters for recreational sportboat? Tim.M OnBoard Electronics & Controls 15 04-25-2009 05:34 PM
Teleflex DIY Mack77 Powerboats 0 06-24-2008 08:20 PM
