| Displacement - much more Help me understand please - sailboat displacement - to me you have heavy, in the water (sticky) and you have light, out of the water (not sticky) Sticky being surface area. I suppose the goal is to find something in between.. So what would happen to say for sake of discussion, a westsail 32, we all know this boat - a hull speed heavy displacement boat with a comfortable motion, What would happen if we duplicated the 32 all in carbon fiber? If we kept the original ballast weight Im sure the boat would be much higher on her waterline. Ok, now we have to add additional ballast to bring her on her lines. Now with all that additional ballast you can add a taller more powerful rig. If you did that then wouldnt you have a boat with a very violent roll and motion? Suppose you kept the original rig with all the addiotional ballast - what would happen then? |
| The boat would of course be stiffer. You can lighten any normal hull and put the weight back down low, given enough money and effort. Then you'd carry sail longer before reefing, and consequently the stresses on the rigging would increase, meaning the rig would require, on average, some upgrading to deal with those higher stresses. Rolling would increase too. Comfort aside, the boat would sail and resist capsize better. Of course, you can do this to any normal sailboat. You can throw money at anything but the same investment in a larger boat would be preferable because you'd get more space and more speed/safety as well all things being equal. |
| You'd need a stronger rig and several other not so obvious upgrades as well. |
| Ok, I think I get it - |
| The increased roll accelerations of your hypothetical Westsail 32 will be mitigated by the taller rig with more sail area. It is possible the modified boat will have a more comfortable rolling motion with lower roll amplitudes and less roll acceleration. |
| Displacement or Semi-Displacement Hull | waynep | Boat Design | 24 | 10-05-2010 09:01 AM |
| Displacement | ROBERTABC | Boat Design | 9 | 12-20-2009 05:30 PM |
| Displacement | Design_1 | Wiki | 3 | 04-05-2007 07:47 PM |
| Displacement distribution | Wardi | Sailboats | 22 | 06-03-2005 12:57 AM |
| Barge Displacement | djreidt | Boat Design | 1 | 07-04-2004 09:04 AM |
