Old 09-04-2006, 09:19 PM
c&sautomarine c&sautomarine is offline
determining mast height
Thinking of designing a boat a foot longer and faster than a flying scot. wondering if there is an equation to figure mast length using the dimensions of the hull.
email address
cschrak182@aol.com
Old 09-07-2006, 06:47 AM
Rep: 1729 Posts: 2,464
Depends on several factors.
I suggest you read some good books on design before you start this road. If you are simply lengthening the same design by stretching longitudinally then the stability will not be much greater. Look up sail area ratios and calculate your mast height from all the factors of the design. If you want to post more specifics we can probably help.
Cheers
Mike Johns.
Old 09-10-2006, 06:36 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
There used to be an old formula in Holland: regular sailingboat: 1,1 x loa;
racing: 1,2-1,4
This is just a rule over the thumb.
Transome height SC1 Powerboats 3 05-13-2006 12:48 PM
determining distance between catamaran hulls Thai Boat Design 4 03-31-2006 11:07 PM
Wave height/swell height netjaws Open Discussion: All Things Boats & Boating 6 11-06-2005 05:43 PM
fiberglass roll; determining length by weight and width? GrantC Materials 5 03-07-2005 07:07 AM
Determining draft ted655 Boat Design 25 02-09-2005 07:37 PM
