Old 04-01-2007, 11:17 PM
EAP EAP is offline
Rep: 10 Posts: 9
Designing Gaff Rigs
I'm Looking For Any Credible Information On Designing And Sizing Gaff Rigs, Ie: Shrouds, Stays Etc. At This Moment I Am Using 'pricipals Of Yacht Design' Lars Larrson, Knowing It Is More Geared To Sloops And Fractional Rigs. I'd Like To Be Able To Verify My Findings.
Any Input Would Be Greatly Appreciated
Earl
Miami, Fla
Old 04-02-2007, 01:33 AM
Rep: 206 Posts: 391
See if you can get a copy of "The Riggers Apprentice" by Brian Toss, it has a lot of detail on rig design and much is aimed at traditional type rigs.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 04-02-2007, 05:19 PM
ukebert ukebert is offline
blank
Rep: 10 Posts: 18
There's a lot of information in "The Gaff Rig Handbook", but almost certainly not technical enough for what you want.
Boat (bōt): A hole in the water, surrounded by wood into which one pours money.
Old 04-02-2007, 06:04 PM
Robert Gainer Robert Gainer is offline
Designer/Builder
Rep: 44 Posts: 142
Yacht Designing and Planning by Howard I Chapelle has information on designing a gaff rig.
All the best,
Robert Gainer
Old 04-02-2007, 09:02 PM
Rep: 2891 Posts: 8,789
In most gaff rigged craft, the loads are not particularly high, especially when compared to modern Bermudian racing rigs. They typically are designed overly stiff, heavy and redundant and operated rather slack by current practices in high aspect rigs. The point loading and panel strains should be well documented in several books, including some of the noted above. Rigging specifics covered by Herreshoff, Chapelle, Leather, Cunliffe and others favor galvanized wire (usually of different construction then what is available today) and hand splicing. Adjustment to wire and terminal sizing will need to be made to account for different material properties and working load limits. These are all readily adaptable with fitting and wire manufacture spec's in hand. A very general rule of thumb used by these old salts, was take twice the displacement of the vessel and make this the working load limit, for the likely weakest link in the rig. Ideally the whole rig should explode just after this limit is reached, if everything is sized properly, but then in this world, the seas would always be glass like and blowing 10 knots on your beam, continuously, until you need to come home, when the it would clock around 180 degrees.
Old 04-07-2007, 10:17 AM
Cliff Pope Cliff Pope is offline
Rep: 10 Posts: 21
I have found Gaff Rig by John Leather invaluable in re-rigging a small traditional gaff cutter.
Lots of practical examples, diagrams and photographs, and the odd warning against "theatricality" - ratlines, etc.
Aftmast rigs??? jdardozzi Sailboats 489 02-11-2012 07:22 AM
Sail Rigs john.G Sailboats 24 10-23-2006 10:37 AM
junk rigs geoffr Sailboats 20 05-01-2006 08:10 PM
Reactive rigs yokebutt Sailboats 1 04-07-2005 05:46 AM
Cruising Sail Rigs brian eiland Sailboats 0 07-31-2004 10:55 AM
