Old 10-30-2010, 07:29 AM
Rep: 206 Posts: 391
Design Optimisation
For those interested in developments in yacht design technology, I have uploaded a copy of my PhD thesis on "Stochastic Optimisation of America's Cup Class Yachts" to this page.
Access to the thesis had previously been restricted at the request of the Alinghi team, but with the selection of catamarans for the next America's Cup, Alinghi have kindly waived this requirement.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 10-30-2010, 11:16 AM
CutOnce CutOnce is offline
Rep: 205 Posts: 470
Thank you for posting your thesis. I will enjoy reviewing it and learning. It is academic sharing that allows the world to progress.
CutOnce
Old 10-30-2010, 01:06 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,604
Thanks very much,Andrew!
yes, it is a revolution
Old 10-31-2010, 12:56 PM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1816 Posts: 1,422
Congratulations! And thanks for uploading the thesis.
Old 10-31-2010, 03:42 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
...thanks Andrew, it is a very interesting article and even though i will not understand half of it, what I have read is inspirational and thought provoking in the methods utilised. Ta, John
Old 10-31-2010, 04:25 PM
Michael Y Michael Y is offline
Rep: 10 Posts: 8
I very much enjoyed the short paper, and will read the thesis. I'm a budding boat builder and designer, which is one connection to your work. My PhD advisor was Dr. Simpson (you referenced a paper of his) so there's another connection.
Give this a look...might resonate with your work.
http://www.atsv.psu.edu
Old 10-31-2010, 11:46 PM
Rep: 206 Posts: 391
Thanks Leo
Although you are not directly cited in the thesis I do owe you a debt of gratitude for providing some of the initial inspiration for the work.
And I should also congratulate you on your PhD, I have your thesis on my iPad and am slowly working my way through it.
cheers
Andrew
Andrew Mason
Formsys
Maxsurf Academic
Old 11-01-2010, 12:01 AM
Rep: 206 Posts: 391
Thanks Michael, I hadn't heard of the Trade Space Exploration approach before, it looks quite interesting. I'll have to do some reading.
Dr. Tim Simpson has done some excellent work that I used extensively, I really appreciated his ability to sort the wheat from the chaff when it comes to sampling and surrogate modelling. What was your thesis topic?
Andrew Mason
Formsys
Maxsurf Academic
Old 11-01-2010, 03:08 AM
Thanks Leo
cheers
Andrew
Thanks, Andrew.
I think our approaches diverged a long time ago - you headed for CFD, I do everything I can to keep away from the beast.
I also wanted to do some work on ship motions in waves and added resistance, but when I suggested it to Ernie Tuck he replied, "I never want to touch that subject ever again!".
Old 11-01-2010, 07:41 AM
Rep: 10 Posts: 8
Neither of those two.
My thesis topic was on fast algorithms to identify the Pareto Frontier from large multi-dimensional data sets. The algorithm is the one that operates in ATSV. One of my cohorts did his work in using Krieging to model uncertainty in order to allow for rapid uncertainty propagation in complex models.
I teach a course in flight test right now, and have occasional thoughts about trying to teach one in yacht design. Have to learn it first, though. Super interesting subject.
The trade space stuff is useful if you have multiple criteria you are trying to satisfy. In your case, the tournament seems to provide a nice, neat scalar number to optimize. But since what you are actually doing is comparing distributions of outcomes between yachts, maybe it would be interesting to visualize not just the expected values but the median, mode, standard deviation, etc. Also, you could consider min-max solutions and look at that space.
One question I had is, for all the different yachts you are racing in your tournaments, would the tactics you'd use for one yacht be different than the tactics you'd use with another? Would you sail them differently to extract each one's best performance? Or would you sail yacht A different when racing yacht B as opposed to racing yacht C? I think the answer is no, since they are close to each other in design. But if the answer is 'yes', are you doing some sort of search over the tactics space too?
Old 11-01-2010, 10:04 AM
Rep: 206 Posts: 391
The variance in the win ratio is directly related to the diversity in the population, hence the need for techniques that promote diversity such as fitness sharing, niching, hall-of-fame etc.
If the intent is to rank designs then you need identical tactical models, as what you are effectively doing is two boat testing, keeping both boats in as similar a set of conditions as possible.
If the intent is to simulate races to investigate the effects of different tactical models, or the effects of different design parameters on maneuverability, then yes, you might look at sailing the boats differently.
Keep in mind that while the ACC V4.0 rule allowed a wide range of displacements, sail areas and lengths, the V5.0 rule effectively fixed these three key design parameters. The result was that the boats could be considered to have negligible differences in maneuvering characteristics, particularly as we did not vary keels and rudders. So eliminating all tactical differences between the boats was a reasonable assumption for the purposes of comparing hull designs.
Andrew Mason
Formsys
Maxsurf Academic
bulb design & optimisation strather Sailboats 8 11-17-2009 12:39 AM
Optimisation with Michlet julien Software 11 11-22-2008 06:22 AM
Optimisation for VPP's DSmith Sailboats 3 04-14-2006 10:04 PM
Centreboard optimisation abindoff Boat Design 11 03-26-2006 09:15 PM
