| Design Identification Just bought a new project, design is unknown so I am hoping someone may be able to help. 19ft long, diagnonal strip planked, (round hull), sloping stern, Bilge keels, V Berth and single berths under cockpit seats. Although it has an outboard bracket, there is a hatch at the rear of the cockpit which I suspect may have been intended as an outboard well. Wooden mast around 20ft long. ![]() I believe it was designed for use in Macquarie Harbour? |
| Check this thread: Can anyone identify this boat?
| That isn't strip planking, but a molded hull, possably Ashcroft method, but certainly a molded hull. It also looks home built. It may be hot or cold molded, but further investigation into it's build type would be required. It looks like one of several possible designs, have you more photos? |
| Perhaps Uffa Fox ? Bilge keel development article http://andycunninghammarine.co.uk/do...nTwinKeels.pdf |
| Thanks for all the responses anod references so far! Looking at the lines I don't feel it is any mentioned or pictured in links... One thing that may helpis the transom is of modern style/design sloping towards to bow at the top. I will certainly post some more pics, any particular views or reference points that may help? Thnks again |
| The bulk of the vessel is in good order, the original fiberglass sheath has been removed. There is the patch on the bow to repair and there are a couple of spots in the decks with rot. (there is also a couple of very average repairs!) The intention is to replace the whole deck (considering the amount of deck, I think the end result will be better for less work (decks still have fiberglass on them) Then fill, fair and sheath the hull with 200gsm cloth and epoxy. |
| More Pics ![]() ![]() ![]() ![]() |
| Identification needed | sirclippliers | Sailboats | 8 | 05-31-2011 03:38 PM |
| boat identification.please help!!! | chappers69 | Open Discussion: All Things Boats & Boating | 7 | 04-18-2009 04:55 AM |
| identification of boat design by picture ? | snoozer | Boat Design | 0 | 04-27-2008 06:02 AM |
| lifeboat identification | Evert | Wooden Boat Building and Restoration | 0 | 03-26-2008 08:16 AM |
| Boat identification + design input needed please | ericvj | Boat Design | 0 | 11-27-2005 10:22 PM |
