#121
| At a given speed a foil with fixed pitch should deliver fixed lift. Much the same as a crew of given weight cannot deliver more than a certain righting moment. The need to adjust sail to suit conditions shouldn't surprise anyone in a boat, DSS-equipped or not. Heeling moment tends to rise faster than the resulting speed for a displacement hull. I believe foil lift is proportional to the square of the speed so if there is adequate DSS lift in a moderate wind there should be adequate lift at the higher speeds obtained with a heavier wind. However, heeling moment builds instantly, speed and foil lift build rather more slowly, so sail drive needs to be tapped gradually. But surely any crew would know that? Of course this is not a rigorous analysis: maybe the foil angle is incorrect.
#122
No, it's not(at least it is very,very unlikely)-the boat has won races with the foil as is and did pretty well in this regatta. There was ,obviously, a crew judgement problem in that the boat was overcanvassed for the conditions-as stated by the SA poster.
#123
#124
I always get suspicious when plane crash investigators conclude it was caused by pilot error.
#125
| Dss Quote:
Good question, Terry.
#126
There isn't enough experience with DSS in race conditions for anyone to have all the answers yet, especially those of us constructing post mortem analysis from the Internet. As in most debatable situations you have to defer to first hand reports, unless incontrovertible evidence is available to counter them. If the anecdotal reports are to be believed, the confusing rough sea state appears to introduce a lot of variables to predictable benefits of DSS. The ability of the crew on the Shaws to independently watch, anticipate and instantly make righting moment adjustments in the conditions may have been a factor - as well as eliminating the work of handling the DSS foils. The results seem to indicate that the predicted benefits of DSS may be mitigated somewhat by race conditions. As conditions get more challenging, the crews that can keep their heads outside the boat generally do much better. -- CutOnce |
#127
| Dss Quote:
Any boats' results may be mitigated by race conditions. There is no factual evidence, whatsoever, that handling the DSS foil was, in any way, responsible for the problems the boat had in race one where the crew was sailing with the boat overpowered for the conditions, according to the SA poster. Again, the boat got third overall despite a DNF in race one.
#128
| In the pics of B3, in the SA link, sailing upwind the DSS board is sticking out to weather. Do they tack the board or does it just stick out both sides? Pic would indicate that it sticks out both sides, so there isn't really any handling of the DSS system |
#129
DSS foils DO move from side to side - and the reasons for doing so are pretty obvious. Failure to move a DSS foil (as in the picture) is most simply explained by "It wasn't worth the effort or time, given the circumstances". This provides a plausible train of thought that may (or may not) be worth following: If 50% of the righting moment benefit can be gained without crew action, the crew may defer moving the DSS board because they are too busy, may be anticipating a need for a fast tack, may be occupied with sail handling, conditions do not require full righting moment etc. Keeping the DSS foil in a middle position supports the "keep heads out of the boat principle" quite well. Only the crew in place at the time can provide answers. Logic states there must be some reason why they've consciously chosen to center the board. -- CutOnce |
#130
Of course I don't always believe what I read on the internets. Those charts looked familiar. A quick check at the DSS site revealed a powerpoint sales pitch to Wally from 1988. Guess what the charts look like? The versions <removed> presented have had the date removed. I'm sure there was a reason for that. Last edited by Boat Design Net Moderator : 05-22-2012 at 08:36 PM. Reason: Reported post: "namecalling" removed |
#131
In my post I suggested the crew had attempted to exceed the limits imposed by the available DSS lift, that is not quite the same thing as using excessive sail area for the conditions. The distinction is subtle but may be important. When the crew commented on pitch angle perhaps they meant that DSS lift can be increased with increased attack angle to permit more sail to be carried. I imagine optimizing foil angle will be part of the learning process for DSS users; also any new boat goes through a tuning period. My suggestion raises the possibility that the life will be excessive causing surface penetration and additional drag, but that can - I imagine - be improved by moving the foil inboard.
#132
| Dss Quote:
The board is tacked side to side on most DSS boats done so far except for test models. Much data was gained on the experimental 27 footer by leaving the board out on one side only. Both BBB and the Quant 28 use sliding boards; the Quant 30 uses dual pivoting(like a centerboard) DSS foils. Welbourn supplies the boat owner with data showing at what speed the boats L/D ratio is improved using the foil-it may be that in the picture showing the board to windward the speed was too low for the board to be effective. Look at the info for the big boat-the board shows and improvement at fairly low speeds. The picture below showing BBB going upwind shows the board retracted-which is why it sticks out on the windward side: Pix-Quant 28 at rest-click on image:
#133
| Dss Quote:
Terry, so far none of Welbourns DSS boats has a foil whose angle of incidence can be adjusted.The foil has a fairly wide range of + lift-well over two degrees-even with a slightly negative angle of attack-say -1.5 degrees. Also, retracting the foil partially will increase drag because it decreases aspect ratio. If the SA poster is right then the crew did overpower the boat which would have a negative effect on any boat. The comments related by the SA poster and attributed to the crew regarding the foil don't make sense to me.
#134
All foils have some lift left at negative incidence, that’s normal. Retracting the foil partially would increase drag-lift ratio but should reduce total lift IMHO . . .
| Sailing Foiler Design: Foil Assist and Full Flying | Doug Lord | Hydrodynamics and Aerodynamics | 15 | 02-13-2012 10:21 PM |
| Quant 28-foil assist keelboat / DSS | Doug Lord | Sailboats | 42 | 12-24-2011 02:23 PM |
| DSS for "Foil Assist" on Multihulls? | Doug Lord | Multihulls | 7 | 03-05-2010 04:13 PM |
| No Foil Assist on IDEC | Chris Ostlind | Multihulls | 6 | 08-21-2007 05:24 PM |
| Groupama 3-almost 800-Foil Assist! | Doug Lord | Multihulls | 16 | 07-31-2007 06:14 AM |
