  #31
Old 02-10-2012, 08:49 AM
peterchech peterchech is offline
Rep: 127 Posts: 220
Originally Posted by Perm Stress View Post
If THIS is "porpoising like mad", what is "steady", than ?
You have to watch the video. Towards the very end, on a downwind course with the asym spinnaker up they are indeed porpoising badly. On a downwind course, that foil should be able to be pulled in entirely. Lack of buoyancy in that fine bow may be more guilty than the foils though.
It looks like they are choosing to keep the foils half extended on each side for the whole video. I wonder if they are even movable at this point.
A more instructive video of the concept would be some video of a close hauled beat, where the alleged benefits of the system would be most pronounced.
  #32
Old 02-10-2012, 09:24 AM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,604
Porposing!? No thats called "going over waves"... No way that is porposing which would be a similar movement in the absence of waves!
The "alleged benefits" of the system are clear cut on any point of sail where the foil is active according to those who have sailed a DSS equipped boat.
Quant 28:
http://www.youtube.com/watch?feature...&v=DwDGKghV8fU
yes, it is a revolution
  #33
Old 02-10-2012, 09:47 AM
aka Terry Haines
Rep: 1814 Posts: 3,009
Looks straight and smooth; of course that is almost flat water. Couple more here, in the second one the boat is handling chop and crossing the wake of the powerboat with about the amount of bucking you would expect -
http://www.youtube.com/watch?v=A8A9GIKyqcI
http://www.youtube.com/watch?v=D-ogo...eature=related
Dances with Turkeys
  #34
Old 02-10-2012, 09:51 AM
Doug Lord's Avatar
Flight Ready
From Hugh Welbourn on the Quant 28 and DSS:
Originally Posted by Doug Lord View Post
Sound bites from Mr. Welbourn-(from SA)- addresses question I and others have had:
Draaaag....and no, none us do drag without a good reason)
Look at it this way - every item in the water causes drag, so to be there it has to have a good reason to be doing something important...so keel holds a lump of lead on the end and also provides sideforce which you need. Rudder produces sideforce. Both have viscous and induced drag but you need them.
Hull supports the thing in the water thanks to Archimedes, and has viscous, induced ( from leeway ) and wave drag.
So the DSS foil adds viscous and induced drag, but also can operate in various modes depending on immersion depth - so close to the surface it can be a nice effective planing surface, partially ventilated then likewise but a lot of the viscous drag has gone and if its got there then you aren't using all the RM/lift that it might be producing so it doesn't need to be working hard as a fully immersed foil.
Lift and RM....both are significant, and each design has its own requirement in how to best approach the foil and overall balance.
If you look at the video then you can visibly see how little the hull is contributing to wavemaking, wetted surface is low and also well aerated, and so we're bimbling along steady 15-16 knots and maxed 17 in about 10 TWS and only three up - me driving, German Journalist along for the ride and Kos up front.
Boat is in perfect balance, wouldn't be doing those numbers without the foil.
Bit later on the breeze came up from a thunderstorm and we were doing the same numbers and a bit more just on the working jib.
Lots more video from that day, and the weather side views make it look as if nothing is happening - practically no spray, stuff all hull in the water. But note, I'm not trying to fully fly the boat as then you get into all the trim problem - so its designed to have natural dynamic stability.
And btw - we've done extensive testing on the 27 in big waves and seas down off Sotogrande and never had any issues from launching off waves or burying or any signs of tripping.
Upwind - well the thing here is to match the wing parameters to the boat so that the net result - in steady state - is just slightly in your favour. So RM gain outweighs the drag cost.
However, what we then find is that as soon as there's any chop or seaway to move the boat around, then the damped motion in all axes makes a significant improvement that is seen on the VMG - even when you only seem to be sailing maybe a tenth quicker than you might. Now that comes from logged data and was a bit of ( pleasant! ) surprise to me until I figured out the dynamics of what was going on.
And don't forget, you don't need to use the wing at all until you are running out of natural RM, so no draaaag....until its starts to work and then the balance is in the your favour.
Its all a pretty finely balanced configuration but we've got a good handle on thing now from all the r&d and sailing and how to configure the different types of boat to work.
Downhill vmg - then same again - if you don't need the wing trickling along then its out of the water, but as soon as you can get into the situation where you can AWA sail then the more power you have to use the better. Bit like cats or skiffs, but cats can't get the spare hull out of the water until theres enough breeze, and skiffs or canters all have a fixed max RM.
So the AWA you sail on the 28 downhill is always well forward, but the angles you actually gybe through can be less than more conventional boats.
Thing is, got two boats in one here - the light wind one is skinnyish with very low drag, but you can add in the grunt when you need it....
Start of the Bol d'Or - dead downhill, bit of breeze - ourselves and the 36' trapeze/canter Full pelt bolted off the line at 15+ and were a mile clear of the fleet in 10 minutes - and crossing gybes with some of the cats that started 300m in front of the mono fleet....they were a bit confused to see us in 'their' water
  #35
Old 02-10-2012, 09:56 AM
Doug Lord's Avatar
Flight Ready
Dss
Thanks for the video's ,AK I loved the one with "Brace, Brace, Brace" passing the multihulls!
  #36
Old 02-10-2012, 05:20 PM
Perm Stress's Avatar
Perm Stress Perm Stress is offline
Rep: 323 Posts: 523
I did.
I did see smooth and steady sailing.
the bow is a little depressed at times, what is no surprise at all, with all the extra driving force made possible by extra righting moment.
All the stresses in my designs are 95% of permissible.
  #37
Old 02-11-2012, 06:35 PM
Doug Lord's Avatar
Flight Ready
Dss
An interesting thing about DSS is that it appears to be applicable to many(but not all) designs from about 10'(mostly downwind) to virtually unlimited. It's going to be interesting to follow developments as time goes by. One thing I'd like to experiment with, at some point, is an application on small planing hulls that will allow the angle of the incidence of the foil to be changed while at the same time giving excellent access to the foil and incorporating a control line system right at the cockpit.
Here is a rough sketch of the potential system:
click on image-
Design for DSS-Foil Assist for Keelboats-dss-foil-system-small-boats-simplified-version-2.jpg
  #38
Old 02-12-2012, 05:20 AM
Rep: 457 Posts: 1,404
That boat is NOT porpoising, riding through waves, yes, but not porpoising - you're reading/seeing what you want to negatively believe ... but it is not so. Another point': all this talk of negative attack when the bow goes down is also fantasy talk: have you ever sailed on any type of foil boat? I would say no ... because even when the bow goes down, you don't get a negative effect operating on the foils (because of rotational movement in waves) - and I'm talking about fixed foils at say, 3 degrees angle of attack, not movable versions - the foils continue to do there job of lifting even when at acute boat angles in waves.
Sorry cobras, the DSS system works and will continue to be refined. I'm waiting to when they discard the bulb keel entirely (maybe have optional water ballast) and rely entirely on the foil. Then you'll start seeing real multihull-like performance.
  #39
Old 02-12-2012, 08:10 AM
CutOnce CutOnce is offline
Rep: 205 Posts: 470
Many of the comments to date are objective - and objectivity mean you look at all aspects of design - not just the superlative. Otherwise we might be better to label this forum BoatHype.net. And your label of anyone presenting other points of view as "cobras" is questionable.
DSS has positive aspects. High density lead bulb keels have positive aspects. Both have negative aspects. Water ballast has limited application to augmenting righting moment - but it does not provide the simple, reliable and failsafe benefits of keel bulbs in recovering a knocked-down hull.
This forum is of very limited value if all the positions discussed and presented are in unquestioned support of whatever the current flavour of the week technology.
CutOnce
  #40
Old 02-12-2012, 10:12 AM
Doug Lord's Avatar
Flight Ready
Dss
CutOnce
On the other hand, a few of the comments were not objective or technical in nature but plain rude and/or uninformed: "goofy design" and assesments of DSS based entirely on a video described as showing a boat "porposing" implying that it was doing so(actually it was going over waves,not porposing!) because of DSS. Comments that far from reality accomplish nothing and Gary was right to point it out.
It's important to understand that a boat that gets a heavy gust and gets knocked down will be much quicker to get back on her feet with DSS because the rotation of the boat increases the angle of attack of the foil almost instantly. This is not speculation but rather an observed characteristic of the use of the foil by those that have sailed it and designed it.
Some of the comments seem to ignore the fact that DSS equipped boats(so far) all have lead keels as well! DSS boats equipped with lead keels obviously have two times the benefits of either separately, right?!
It seems to me to criticize this technology you would need to have first person accounts of the failure of the technology by someone sailing it as opposed to uninformed speculation and/or some technical basis for saying that the foil doesn't work backed up in some way that forcefully illustrates the point.
Pure uninformed speculation doesn't cut it in the face of many first person accounts of the foil working well, as well as videos and race results showing the same thing.
  #41
Old 02-12-2012, 10:38 AM
aka Terry Haines
Cutone (Bill?) is correct that all side of an argument are needed.
If someone thinks it is porpoising then they have the right to express their opinion.
Gary and several previous posters are also correct that the boat is not porpoising.
Dances with Turkeys
Last edited by ancient kayaker : 02-14-2012 at 04:07 PM. Reason: deleted last 2 lines after mature consideration
  #42
Old 02-12-2012, 12:17 PM
sean9c sean9c is offline
Rep: 35 Posts: 85
I re-read all the posts on this thread I can't see where anyone posting has enough knowledge of the DSS system to make objective statements about it's performance or benefits. We're all making subjective statements based on what little data is available.
  #43
Old 02-12-2012, 09:52 PM
aka Terry Haines
Originally Posted by sean9c View Post
. . . We're all making subjective statements based on what little data is available.
That is true, but there are DSS boats that are demonstrably and visibly working for us observe and discuss in order to try to understand the theory and practice.
The DSS in principle moves part of the lift/buoyancy of the hull outboard to leeward. From a RM point of view this is functionally equivalent to moving the weight of the crew outboard to windward by hiking out. Whatever righting moment the DSS provides can be treated as additional to permit increase sail power, traded for reduced crew hiking, or traded for -perhaps a narrower hull for reduced wetted surface. Maybe other options too.
Reducing the need for crew hiking would allow either a smaller crew (longer range with given stores?) or permit the crew to focus more on active sailing. One would like to say that bringing the crew back inboard again is an opportuity for a safety gain, but if performance is driving the design the extra RM will go into a bigger rig.
So we can have improved performance from a given size boat, or less demand on crew and skipper in the interests of more range/more comfort/larger boat-to-crew ratio/ or whatever.
Sorry to ramble - not yet sure where we are supposed to be going in this thread . . .
Dances with Turkeys
  #44
Old 02-13-2012, 06:45 AM
Rep: 205 Posts: 470
The problem with the observation to date is that what we are seeing is limited to what people want us to see.
No one has even mentioned the elephant in the room. The point of sail where you need the most righting moment is when you are going hardest to windward. This is the slowest point of sail. Given that DSS is dependant on flow across the DSS foil to generate lift, this is the least effective point of sail for the DSS foil, as it is the slowest. And transitions from tack to tack are worse - as they are slower. Given that crew will be busy shuttling the DSS foil from side to side during tacks, I don't suppose tacking will be faster than a non-DSS boat and more speed will be carried throughout. And I sure hope no one blows a tack and gets into irons - that DSS foil is not going to be a help going backward.
The faster the point of sail, the more effective DSS becomes - so videos of broad reaching are showing the technology to it's best advantage.
Every design element is a compromise of benefits and liabilities, and DSS is no different. It's designers and promoters have investors to answer to. I would not expect someone hoping for financial success from a technology to present it's warts and promote it's downsides. This isn't a negative comment, it is a statement of business reality and human nature.
As I tried to outline earlier, the conditions in which sailing occurs contains far more variables than most other "machine-borne" speed sports. What benefits speed on a broad reach may have less effect going upwind. What optimises planing may have a negative effect when in displacement mode. Ultra light weight that helps planing performance may make punching through steep confused chop impossible. Each point of sail effectively is best handled by a different boat design with different choices of technologies. There is no one size fits all perfect solution.
Although DSS appears on the surface to be a great technology, I have to agree with Sean9c in the observation that no one here has enough evidence to draw conclusions. It sure looks great in the promotional material published to date, but Youtube always presents all the facts, don't they?
I'm pretty certain this post will be immediately followed by a damning response (as is every post I make). I'm not disparaging DSS' designers, the effectiveness of the technology in optimal conditions or making judgements - I'm just trying to extrapolate the whole picture from limited (and carefully chosen) evidence.
CutOnce
  #45
Old 02-13-2012, 07:52 AM
Doug Lord's Avatar
Flight Ready
Dss
No one has even mentioned the elephant in the room. The point of sail where you need the most righting moment is when you are going hardest to windward. This is the slowest point of sail. Given that DSS is dependant on flow across the DSS foil to generate lift, this is the least effective point of sail for the DSS foil, as it is the slowest. And transitions from tack to tack are worse - as they are slower. Given that crew will be busy shuttling the DSS foil from side to side during tacks, I don't suppose tacking will be faster than a non-DSS boat and more speed will be carried throughout. And I sure hope no one blows a tack and gets into irons - that DSS foil is not going to be a help going backward.The faster the point of sail, the more effective DSS becomes - so videos of broad reaching are showing the technology to it's best advantage.
CutOnce
From Post 34 ,Hugh Welbourn:
Sailing Foiler Design: Foil Assist and Full Flying Doug Lord Hydrodynamics and Aerodynamics 15 02-13-2012 10:21 PM
Quant 28-foil assist keelboat / DSS Doug Lord Sailboats 42 12-24-2011 02:23 PM
DSS for "Foil Assist" on Multihulls? Doug Lord Multihulls 7 03-05-2010 04:13 PM
No Foil Assist on IDEC Chris Ostlind Multihulls 6 08-21-2007 05:24 PM
Groupama 3-almost 800-Foil Assist! Doug Lord Multihulls 16 07-31-2007 06:14 AM
