| when a sailboat heels so much the prop is too close to the surface, you'd most likely be sailing, no? and if you're rolling so much when motoring that ventilation would be an unbearable problem, I'd guess sea conditions are such that ventilation wouldn't be among the top concerns... |
| Sailboat frequenly motor dead to windward to navigate narrow channels or harbor approachs under power. You need a good bite with the prop. The classic example of a bad prop bite is a small day sailor with an outboard motor hung off its transon. When the bow dips into a wave, the stern rises and the motor cavitates in bad water.. |
| No, it does not cavitate. It ventilates. They are completely different things.
__________________ Gonzo |
He is a sailboat "Captain" with many hundreds of thousands of miles at sea, you know? He sails 1200 miles per week. Almost every week. And he does it with a cavitating prop, I guess. |
| Michael: A sailboat heading straight upwind into a harbor entrance would be leeward of it. That means calm water and little wind.
| And only pitching, no rolling. there would need some giant waves to make a relatively long sailor pitch so hard that the props are out of the water... in that case the waves would probably stop the boat from moving, engine or not. |
| BERTIE's off-center prop is about 20" below LWL and will sometimes ventilate slightly when heeled on port tack and it's very rough. Don't think it'll be much a problem with a centerline installation though. |
| Propellor shaft dimensioning | Arvy | Powerboats | 9 | 07-02-2010 06:06 PM |
| Propellor sizing | corglass | Props | 11 | 06-16-2010 03:10 PM |
| What is propellor slip? | Rangerspeedboat | DIY Marinizing | 10 | 05-18-2009 11:46 PM |
| MY propellor is too BIG | rich99uk | Props | 1 | 07-24-2007 10:53 AM |
| propellor-curve? | Guest | Powerboats | 0 | 11-06-2003 05:07 AM |
