| You might also want to check out http://www.zwakenberg.de/hulldrag/ |
| I had another look at Delft recently and set up the spreadsheet as per the 14th Chesapeake paper including a flag indicating if I was outside the tested hull parameters (this was not detailed in the Modern Yacht paper) this now returns more sensible values, though maybe not as sensitive as the Delft 1 & 2 series. |
| Excellent But is there any formula for optimizing LCF position versus Fn? - like the Cp and LCB from Larsson? I am very interested in this. And another problem. What about waterplane coefficient? In my opinion in might be as importand as LCF. But it is often neglected. Any opinions? |
| ibi, Firstly, I agree that LCF "separation" from LCB is important, the only way to analyse this (cost effectively) is to set up a Delft Series spreadsheet and input different LCF locations whilst fixing LCB and Cp, you should then be able to observe the trend. I am now coming to the view that Delft 1 & 2 (as in Larsson) is best for fixing Cp and LCB, and that the recent versions of Delft are good for LCF (using the Cp and LCB values from 1 & 2). My analysis is that the greater LCF/LCB separation reduces residual drag at hull speed (Fn @ 0.35 - 0.40), however you need to observe the boundaries set up by the parent models. Assuming that you are not going for an immersed transom, the LCF position will probably be limited by the practical constraints of creating a fair waterline. I think that your comment about waterplane co-efficient, is pretty well determined by all the other factors, i.e. if your section area curve, cp, lcb and lcf are right and you have a fair hull, the additional variable may be one too many to consider, especially when also having to consider the hull when heeled and in a wide range of loading conditions! |
| For optimum cure of areas info check out http://boatdesign.net/forums/showthr...5&pagenumber=2 |
| Maybe it's worth adding that in 1993 and earlier, all the Delft models were tested with a standard keel and rudder, which were included in the residuary resistance polynomial. The more recent formulations include separate expressions for appendage residuary resistance. This is perhaps important because the Delft standard keel and rudder are not very representative of recent practice. Moreover, for light displacement hulls, the contribution of the appendages to the total residuary resistance is pretty significant, as much as 30% for one of the earlier Delft models that I looked at. So I concluded that the more recent polynomials should be prefered, unless your keel is like the Delft standard one, or the displacement is so large that the appendage residuary resistance is negligible. |
| I have no access to the recent Delft series polynomial coefficients. Could anyone send them to me? I think, that they are public domain - they were presented in public. So there should be no problems with the copyright. Thank You! |
| need series 64 hullform. pls help....... | gmjoarder | Boat Design | 1 | 04-18-2005 08:35 AM |
| Quick,easy, chep & permanant repair for VP 200 Series tilt lock Mech | woodstockwizzar | Boat Design | 0 | 11-17-2004 12:01 PM |
| new delft systematic series? | MaxFratt | Sailboats | 1 | 10-14-2004 05:40 AM |
| series 60 lines / CAD file | DaveB | Boat Design | 0 | 08-09-2004 03:12 PM |
| NPL Series | sarathes | Boat Design | 0 | 04-07-2004 09:05 PM |
