Old 11-25-2006, 02:49 PM
Kiteship Kiteship is offline
Rep: 81 Posts: 136
Definition of Sailing?
Seems trivial enough. We all "know" what it is, so it should be simple enough to define, right?
I'm having a significantly hard time at it, though. I want a succinct, accurate, exclusive definition of "sailing." I want to to encompass all known forms of sailing (including land and ice sailing--and also theoretical ice-ice and land-land sailing), and exclude forms of wind powered motion which aren't sailing (using a turbine to charge a battery, then using the battery to move the boat; or using potential energy to story transient vagaries of wind, as sea birds do). I want to include Peter Sharp's "powered alternate sailing" (if you aren't familiar with this you should be; it's fascinating), but should probably exclude "solar sailing" (though photons have no mass, they do posses momentum--so sailing using them should be possible. OTOH, "sailing" ought to require two fluids (or other material media), it seems to me and solar sailing only has the one--it uses gravity as a second "working fluid", which clearly isn't kosher. (I think!)
I am also having trouble including such simple "sailing" as a leaf (or a clipper ship) being blown DDW across a pond; if this is not sailing (no second "medium;" the water need not be involved), then what is? (eg; if a leaf blowing across a pond is sailing, then why is a leaf blowing through the air, not?) No, it isn't just about drag; If I use a kite to pull a hovercraft DDW, the friction is trivialized--but I am still clearly "sailing," or at least motorsailing)
"Interface vehicle" is the most succinct I can manage to date, but I don't pretend it is a sufficient definition. (and damn, "most succinct" smacks of redundancy itself!)
What do *you* think?
Cheers,
Dave Culp
Old 11-25-2006, 03:25 PM
gggGuest gggGuest is offline
Rep: 64 Posts: 396
And so does every flecible sailboat rig - its a key factory in "gust reponse"
Its kosher enough in the Racing rules of sailing:-)
I think there's why you're getting in trouble Dave, you're attempting to posit a rigid boundary to a flexible condition... I don't think you can get a rigid definition.
Old 11-25-2006, 03:52 PM
Rep: 81 Posts: 136
But, you don't even offer a flexible definition. ;-)
What *is* sailing?
D
Old 11-25-2006, 05:10 PM
Crag Cay Crag Cay is offline
Rep: 572 Posts: 635
To use the power of the wind alone to move 'a vessel' to a given point decided upon by the skipper.
This eradication of mearly being 'blown along', seperates sailing from trash in the street, leaves on a pond and Westsail 32's.
Old 11-25-2006, 05:17 PM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
Sailing may be defined as the act of going somewhere across water, propelled by the wind and supported, primarily by bouyancy due to displacement of said water.
Tim B.
Old 11-25-2006, 05:21 PM
Doug Lord
Maybe: "Non-random movement as a direct result of wind pressure"
Old 11-25-2006, 05:46 PM
Rep: 81 Posts: 136
Sailing is not limited to wind, or water. What about land sailing, ice sailing, and air-to-air sailing? (also what about solid-solid sailing--it *is* possible)
Old 11-25-2006, 05:50 PM
Doug Lord
There are no limitations on my definition except the use of wind pressure to create the movement and the fact that it is not random movement.
Old 11-25-2006, 06:00 PM
Rep: 81 Posts: 136
You do not need wind to sail, Doug. You could, for instance, use a river's current on a windless day. You could also use a river current, coupled to a heavy craft running on the river's bottom (like land sailing, but using water, not air). FWIW, the craft doesn't need to be underwater, but could be on the shore, coupled to the river current by a line (this is then kite sailing--still not using wind). It is also possible to "sail" between two solid surfaces, so long as they are moving, relative to each other, and so long as you can couple the two together. You can also "sail" between relative moving bodies of water (as between a current and still water nearby) and also in the air, between different air currents (this time you do use "wind" but you use nothing else!)
C'mon folks, let's think harder! There is some good info about this in recent AYRS publications.
Old 11-25-2006, 06:03 PM
Mychael's Avatar
Mychael Mychael is offline
Mychael
Rep: 125 Posts: 479
Hmm, so would you consider flying a glider that uses thermals to provide lift as a form of sailing.?? When there are no thermals so therfore no positive lift, then you are just gliding.
Mychael
Old 11-25-2006, 06:40 PM
Rep: 81 Posts: 136
Typically, no. A glider uses the vertical lift from thermals. Blowing things vertically with vertical currents isn't "sailing," I think you'd agree. However, the reasons why soaring isn't sailing might be helpful in developing a definition of sailing.
FWIW, this isn't *my* definition of sailing--it's not a quiz. Sailing is sailing. What we're looking for is a definition.
D.
Mychael
Old 11-26-2006, 07:09 AM
yipster's Avatar
yipster yipster is online now
Rep: 1083 Posts: 3,337
ok you opened the thread under sailboats
but wonder isnt a powerboat also sailing on water?
a quik look in the dictionairy here:
sail=controlling+fload (thrue)
sailing=to sail+boattrip
Old 11-26-2006, 08:30 AM
Rep: 324 Posts: 591
Utilizing a decoupled flow at an interface of two fluids or a fluid and a solid, to advance a vehicle through or over one of two said media.
Jeez this is getting ridiculous
Old 11-26-2006, 08:42 AM
Rep: 324 Posts: 591
"Sailing boats exploit the discontinuity in fluid flow that exists at the air/water interface in order to propel themselves."
Joseph Norwood
High Speed Sailing-Design Factors- A study of high performance multihull yacht design
1979
Adlard Coles-Granada Publishing UK
Not a complete definition under Kiteships required inclusion of land sailors.
Old 11-26-2006, 09:02 AM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
not original, but. . .
Going nowhere slowly at great expense.
And my addition.
Going there a little faster at excessive expense.
LP
God bless the open minded people of the world. LP
Quality definition Andante Boat Design 8 11-30-2005 05:27 PM
fiberglass definition rturbett Fiberglass and Composite Boat Building 2 09-06-2005 11:52 AM
Hard Chine Definition Needed Phosphor Boat Design 16 07-09-2004 10:11 AM
Definition - AMA JOFRACON Wooden Boat Building and Restoration 13 04-25-2004 02:31 PM
Definition of AMA JOFRACON Wooden Boat Building and Restoration 0 04-24-2004 04:56 PM
