Old 11-16-2008, 01:45 PM
bluski bluski is offline
Rep: 10 Posts: 2
Deck vs. keel stepped mast on HR 34
I was surprised to see that the mast on the ~2000 HR 34 is deck stepped on thinking that keel stepped masts were more stable (preferrable) and considering many of today's production boats have keel stepped masts. Does anyone know why this may be the case on this upper end boat and what the disadvantages are if any?
Old 11-16-2008, 02:45 PM
Rep: 10 Posts: 2
To answer my own question from already posted info see below:
Deck stepped Mast-Always Bad ?
This is another one of those, "there is no one right answer" questions. I personally strongly prefer a deck-stepped mast over a keel stepped mast but once again this is an area where opinions can differ widely. There is no right answer here. There is a contingent that thinks that the only proper way to step a mast is on the keel. There is a logic to that but it is a logic that can be engineered around and which comes out of a historical context that is less relevant with modern materials.
If you look at this as a structural engineering problem, the base of a mast has a vertical and horizontal thrust to it that tries to push it down through the bottom of the boat and also sideward off of the mast step. In normal conditions the down load is several times greater than the side load. Beyond the loads imparted to the boat, there is also the issue of the loads that happen internally in a mast. When you look at the structure of a mast, spreaders and rigging,it is really a truss standing on end but it does not completely act as truss because in classic engineering terms, the components of a truss are not supposed to have bending loads on them. Ideally, the loads in the mast are primarily axial (acting along the length of the mast) rather than in bending (acting perpendicular to the long axis of the mast). Of course, masts actually do have fairly large bending loads imparted into them. The two most often cited reasons for keel stepped masts being considered stronger is the way that the bending loads (moments) are distributed within the mast itself and the way that the mast imparts its loads into the boat.
If the goal of designing a mast is to reduce bending moments within a mast, the greater the number of panels (segments between shrouds and other supports) the smaller the moments tend to be. In the days when single spreader rigs were most common a keel-stepped mast added one extra panel, the segment between the mast partners at the deck and the keel. With only three panels this extra panel was very important.
The need for this extra panel has became less significant as bigger boats have routinely gone to multiple spreader rigs and moment connections at the deck mounted mast steps.
In terms of the way that the mast imparts its loads into the boat, masts are generally located in the area of the cabin trunk and because of the shape of the cabin (i.e. the deck folds up at the cabin side and horizontal again at the coach roof), this area (if not engineered for side loads) is more prone to lateral flexing than would be the keel. One idea behind a keel-stepped mast being stronger is that a keel stepped the mast is not supposed loads are put loads into the deck.
In reality, this ideal is rarely accomplished for a number of reasons. First of all, if the mast is not tied to the deck or the deck tied to the keel near the mast, either with a tie rod or a tie from the mast to the deck and a connection from the mast to the keel, the downward force of the mast working in opposition to the upward loads of the shrouds can pull the hull together like a bow and arrow, lifting the deck and separating the joint between bulkheads and the deck. You sometimes see this type of separated bulkheads on inexpensive or early fiberglass boats with keel stepped masts.
Not only do keel stepped masts impart vertical loads into the deck (through the ties mentioned above) but they also typically end up imparting side loads as well (if they are going to reduce the moments in the mast as mentioned above they have to). This somewhat reduces the structural advantages of a keel-stepped mast to next to zero assuming that a deck-stepped mast is properly engineered, and that is a big if!
There are several things that I consider critical to engineering a deck stepped mast properly. Primary is having a jack post below the mast. A jack post is a vertical member that carries the vertical loads of the mast to the keel. My preference is to have an aluminum jack post rather than a wooden one but a wooden post can work as well. The other issue is the distribution of the side loads. Ideally there should be a bulkhead or ring frame adjacent to the mast that can take the side loads and distribute them into the hull. These are obviously more complex to do than simply having a fat spot on the keel for the mast step to land on.
My objections to keel stepped masts are to the purely practical. Keel stepped masts mean that there is always water in the bilge. This water comes in at halyard boxes and other openings in the mast and nothing you can do will stop that. Second, it is way harder to step and unstep a keel-stepped mast making the boat more subject to damage in the process.
Beyond that if you loose a mast (I have lost two in my life) it is better in my opinion to loose a deck stepped mast because a keel-stepped mast is more likely to damage the deck when it fails and a deck-stepped mast is easier to clear away. The keel stepped mast advocates point out that you are more likely to end up with a bigger stump after the mast fails. I am not sure that that is the case if you are able to tow the rig as a drougue until things quiet down enough to rig a jurry rig. With a keel stepped mast, I am not sure what you do when the boat is being beaten to death by the upper portion of a mast that has buckled 20 feet off the deck at the spreaders.
My preferred set up is a deck stepped mast that has a welded flange on its bottom that is through bolted through the deck into the top flange of a structural aluminum jack post so that it transfers moment through the deck. My new boat has a keel stepped mast. If I go offshore it is my intent to pull the mast and have it modified to that arrangement if I ever go offshore with her.
Regards
Jeff
vertical down forces on stepped mast Please HELP zambant Sailboats 14 10-27-2008 11:26 PM
deck-stepped mast prob Westwind2 Fiberglass and Composite Boat Building 12 06-14-2008 08:52 PM
deck stepped mast; design question Westwind2 Sailboats 2 05-06-2008 12:47 AM
water in bilge - fact of life on keel stepped mast? mattplowman Sailboats 11 04-02-2008 03:44 PM
Your Opinions on Deck Stepped Masts... Alixander Beck Sailboats 18 05-14-2006 09:53 AM
