| Deck Layout Can someone out there tell me if this deck layout arrangement is smart or has something that can be revised? I also have the .dwg file if someone wants. |
| Hi Nemo.. Race or cruise, how many crew, how big... Anyway, IMHO I would put the foresail halyards + winch on the mast, that way one person on the bow controls the genoa drop (with a turn around the winch if required) and pulls it aboard at the same time. Also dont see any reef lines? If the are left at the mast then leave the main halyard with them. If they come aft have the halyard aft too. Do you really need winches to set up the runners - if its a race boat too much weight, and if its a cruiser then too much cost ? You could put winches aft for the Spin sheets and guys though depends on the application... Also I doubt that you will need to winch the pole up and down on that size boat, - even the main is just qoing to need a "cinch" you could probably get away with one winch for the rest. Why does the genny sheet go through the block on the rail and not straight to the track? Cheers PAul |
| Hi Paul, This is a racing boat (31') I'm restoring, I'd say the crew is 5, 6 persons max. The mast is very thin (maybe I can put online the sail plan), so I wouldn't place a winch on it. Besides, I don't like to have many lines on the cockpit, so I still don't know how to do for the reef lines. Thanks, Stefano |
| Hello Nemo I would put everything in the cockpit so you got one men "playing the pianomen". And if you put a roll in the boom than you can transfer the refflines over the deck in to the cockpit. I woulden't put anything on the mast. well that's what I think. maybe the pic. will help you. Uli |
| I agree with Uli, have all of the halyards etc. coming back to the cockpit winch's, including the pole lift and downhaul which in my opinion will need a winch for fine tuning when flying a spin at a close reach in 25knots. For reefing lines on a boat this size, I think you can get away without having any winch's. Regards, Michael |
| Hi Michael, I think winches are not necessary for reefing lines ont this boat either, so I thought why not placing those lines directly on the boom with some cam cleats? regards, Stefano |
| Deck To Hull Joint | VIKING | Boatbuilding | 16 | 10-06-2008 08:57 PM |
| deck construction | Busted Knuckle | Materials | 12 | 06-26-2006 03:46 PM |
| Bass Boats | dougfrolich | Open Discussion: All Things Boats & Boating | 6 | 06-30-2005 09:24 PM |
| New deck for a 1958 14' Thompson Runabout. | Sultana | Wooden Boat Building and Restoration | 3 | 05-01-2005 10:25 PM |
| Software for deck layout | seahorse | Software | 8 | 02-13-2005 09:44 AM |
