Old 04-23-2005, 05:51 PM
Doug Lord
Daggerboard Position:Interesting Moth
Anybody have any thoughts on the daggerboard position on this very interesting Greg Wise designed foiler Moth?
http://www.moth.asn.au/building/gwise_concept_moth.html
Old 04-24-2005, 10:17 AM
icetreader icetreader is offline
Rep: 12 Posts: 189
Just a thought
Interesting indeed -Maybe the stern is the only point that stays in contact with the water when the moth starts to "fly"
Yoav
fishing kayaks
Old 04-24-2005, 05:32 PM
Andy P's Avatar
Andy P Andy P is offline
Rep: 10 Posts: 95
". The centrecase and mast step support are added (and yes, the mast step is behind the centrecase !). "
and you can see the daggerboard slot on the sketch - and in the build pics.
The idea being to increase the foiling base - ie between the lifting daggerboard T foil, and the rudder T foil.
Not sure how it will balance ( lots of weather helm perhaps ?)
some other boats have the mast moved well forwards, and so the daggerboard can move fwds too. ( but behind the mast )
But the good thing about moths is that you can try things that 'obviously won't work ' .... and sometimes it works fine! ( or at least suggests that next time it will work )
Old 04-24-2005, 05:46 PM
Doug Lord
shared lift
I wonder if Greg has seen the multihull work of Bill Roberts where the daggerboard is forward of the mast as well?
See the following Url; click on the image and then on "Products" and on ARC21 to read about Roberts' concept:
http://www.aquarius-sail.com/
Scow moth....fun looking boats alyne Sailboats 8 06-02-2011 01:28 PM
Sailing Dinghy Design Tim B Sailboats 368 12-15-2004 07:46 PM
Daggerboard sloop? mod flod Sailboats 3 10-09-2004 11:39 PM
Moth on Foils Wins Aussie Nationals! Doug Lord Sailboats 12 02-21-2004 12:16 AM
Help!!!! ( daggerboard construction or daggerboard design ) 01639770993 Boat Design 1 12-29-2003 01:56 PM
