| Cruising Sailboat Hullform I was wondering if anyone knows of any kind of hullform database-type resources pertaining to cruising sailboats. Even a good website with some different boats' design and/or performance characteristics would be good. Thanks for any tips! |
| http://www.image-ination.com/sailcalc.html From the site: Quote:
| Cruising boats are the most difficult for a designer to undertake. They run the full spectrum from de-tuned racers fitted for voyaging to Colin Archer types that can't get out of their own way, but can pack away a whole house of gear, with every possible combination in between. The cruiser is more a state of mind, then a hull type. Each person has individual requirements in a hull that others may not necessary share. Some will have nothing but a full keel, I prefer divided appendages with a shoal draft, everyone is different. Many will talk about D/L ratios and roll moments, but none will be ideal for you specifically, without experience on different types of hull forms. Honest answers about your needs and desires in a cruiser, that only you can provide and your keenly acquired preferences, will guide you to a general pattern, which will ultimately be the hull form you want (or at least think you want). Atkins, Benford, Herreshoff and quite a few others have specialized in cruisers, but you have to know what you want. It's a bit like asking "what's the best automobile type, to take on long trips". There's no correct reply, just questions you have to answer, based on your experience and personal preferences. |
| Like par made clear, several times, "...your needs and desires...", "...Each person has individual requirements...", "...without experience on different types of hull forms...", "...you have to know what you want..." For the older generation, those are familiar names not often mentioned by "young whipper-snappers" , but still worthy of consideration as per first line....I agree with par's suggestion, to get out and look around, sail, and gather personal experiences from which to develop your own personal preferences as to which cruiser for your cruising region. Start with who will be living on board, where will you be cruising, how independently of civilisation should your set-up be, will you keep the boat in a marina & venture out weekends, are you financially independent, The list goes on and on. |
| Thanks very much for all of your advice; unfortunately I am not quite in the market for a boat, however. I am actually thinking along the lines of producing a design, and I am interested in finding or creating a parametric database which can aid me in, among other things, shaping the hull. I was just wondering if there were any resources I wasn't aware of that I could use to that end. SeaSpark's post was very helpful (Thanks!), but I'm also interested in more detail about the boats, such as block coefficient and others or some other data about the hull shape. Thanks to you all for your thoughts. |
| Wolczko, Good to see we did not discourage you any. For entertainment download FreeShip 2.6 - as many on this net seem to use same, & if you cannot find that but get redirected to DelftShip, there is a free version there (which is what FreeShip has become in going "commercial").... It seems that the file format changes so when you present a file for peer review, specify your version. Other members like Rhino 3 - there are polls & other info on design packages in this net - do a search, it is effective. |
| I recommend you read the new Yacht Design According to Perry. He has a number of case studies along with design preferences and justifications. |
| John Vigors The seaworthy Offshore Sailboat opens up some insight into the subject. That is unless one wants to make one more Bavaria/Beneteau/Addanymajorbrandcomesintomind ![]() |
| When you search and ask around, collected data from rating systems like ims, irc and orc will yield comparative figures. Hence you are looking for the bottom line performance boats (cruisers instead of flat out racers) these numbers are more readably available. Not comparative data from http://www.oossanen.nl/ : |
| Thank you again to all of you for your suggestions. I have seen a couple of these before, and I agree that these are good sources. I will look up Perry's book, and I am very much enjoying van Oossanen's work. There seems to be a good deal of information about test results which are in the public domain that I'll have to look further into. Thanks! I'll be continuing to look around to see what I can find about these more readily available numbers for cruisers... Cheers, Wolczko |
| From Principles of Yacht Design.... Very extensive series of tests with models of sailing yachts have been carried out by Professor J. Gerritsma and his co-workers at the Delft University of Technology in the Netherlands. The first series was run in the 1970's and comprised 22 models with a systematic variation of 5 different hull parameters. These first hulls were derived from a Frans Maas designed parent hull. During the 1980's a new parent (more modern lighter displacement form) was designed by Van De Stadt & Partners, with 17 models derived from this parent. Some info on these tests is presented in the book, but also get the papers by Gerritsma. Tad
| Skenes Elements of Yacht Design is a good reference for basic calculations, altho the author has absolutely no understanding of hull balance ,as I found out the hard way. Douglas Phillips Burt also has a good book on design. Brent |
| Thanks very much Brent and Tad... I hadn't heard of Prof. Gerritsma before, and I will certainly get those papers. Cheers for that ![]() Wolczko |
There was a nice followup paper published at the HISWA Symposium that took the information a little further. There's enough math here to make most anyone happy. However, even if you did a perfect optimization, there is no guarantee that you'll get a good boat. However, it is fun! http://www.hiswasymposium.com/symposium_papers.asp |
| Building plans for 26'-28' ocean-cruising STEEL sailboat? | mcm | Metal Boat Building | 29 | 02-17-2011 08:20 PM |
| Delftship to Hullform | Don Case | Sailboats | 7 | 11-20-2007 06:50 PM |
| Someone knows about where to get a HullForm 7 | Çemberci | Software | 3 | 05-03-2007 12:44 PM |
| Aluminum Cruising Sailboat Construction | MikeQ | Metal Boat Building | 7 | 02-14-2005 02:45 PM |
| How do I get offsets into Hullform 8P demo? | Archive | Software | 1 | 06-12-2001 03:44 AM |
