Old 03-23-2011, 08:16 PM
mrdc mrdc is offline
Rep: 10 Posts: 7
could 2 minnkota elec. motors, 36lb thrust each, move a 24' sailboat?
hi
wondering if it'll work?
obviously it wouldn't go fast, but would it troll along ok?
thanks
Old 03-23-2011, 08:37 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
I've read that 50lbs thrust is approximately equivalent to 1HP.
This is just a rough guideline, but useful.
You'll have the same as a little under a 2HP outboard.
The boat will move in calm conditions, but if the wind picks up (and you're not sailing), you won't be able to control the boat.
Old 03-23-2011, 09:21 PM
Rep: 1493 Posts: 7,447
I had a 3.5Hp on a 25 footer and it was adequate. It would go forward against the wind on up to maybe 30Kt of wind. More than that it was marginal. However, if it is windy you don't need an engine.
Old 03-23-2011, 09:22 PM
Rep: 10 Posts: 7
thank you.
how much hp would i need to control it?
5 or 7 or more?
Old 03-23-2011, 09:28 PM
Rep: 10 Posts: 7
sorry i must have posted at the same time as gonzo.
my bad.
Old 03-24-2011, 01:42 PM
BATAAN's Avatar
BATAAN BATAAN is offline
Rep: 1090 Posts: 1,502
Here's a rig another guy and I designed and built on-site in 3 days using 36v trolling motors while working in the Bahamas on Pirates 3 in 2006.
These are in two of the 18' boats and one of the 14' we were using.
I have no idea of the HP but each of these would tow a string of ten or twelve period small boats with actors in them upwind at a fine clip.
could 2 minnkota elec. motors, 36lb thrust each, move a 24' sailboat?-img_3729.jpg  could 2 minnkota elec. motors, 36lb thrust each, move a 24' sailboat?-img_3706.jpg  could 2 minnkota elec. motors, 36lb thrust each, move a 24' sailboat?-img_0453.jpg
Old 03-24-2011, 02:04 PM
Rep: 10 Posts: 7
Sweet set up. I'm thinking this is possible now.
2-4 elec. 30-36lb thr, what can it move? mrdc Outboards 16 05-06-2012 05:48 PM
refrigeration gas or elec taezow Multihulls 52 09-19-2011 07:15 AM
Hyd. Elec for a small Pontoon Mark Emaus Hybrid 0 01-14-2009 04:40 PM
hard-chined 24' ply/glass sailboat- question molerocket Boat Design 14 08-10-2006 12:16 AM
Regulations covering installation of elec. fuel pump fanefarchris DIY Marinizing 2 04-11-2005 06:24 PM
