Old 11-24-2010, 03:58 PM
RHough's Avatar
RHough RHough is offline
Retro Dude
Rep: 714 Posts: 1,622
Originally Posted by TeddyDiver View Post
Skene's describes all kinds of sections.. much more than used commonly today..
round, oval, square, triangular, octagon etc..
Ah yes, Skene's Elements. I wonder if I brought that with me this trip ... great book!
R
Proud supporter of The Far Kurnell Cat Racing Team
I have not failed. I've just found 10,000 ways that won't work.
- Thomas A. Edison
Old 11-24-2010, 04:01 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,055
Originally Posted by RHough View Post
Ah yes, Skene's Elements. ... great book!
Like money in the bank
Old 11-24-2010, 04:28 PM
Crag Cay Crag Cay is offline
Rep: 572 Posts: 635
Perhaps we're trying to be too specific about when changes happened and why. I think the evolution of masts and rigs is more convoluted and complex than a simple time line. The Thames sailing barges trading along the coast of SE England developed a rig where one man (and a dog) could handle 3500 square feet of sail about 100 years ago. About the same as a maxi multihull today.
Again with masthead rig vrs fractional, most gaff rigged sailing vessels had a jibtop stay that went to the top of the top mast. Can't get more 'masthead' than that. Certainly by the 1930s there are plenty of both masthead and fractional rigged boats under both the CCA and RORC rules. In fact the only rule where I can't find any masthead rigs in the metre rule. I will have to have a look at the rule in detail to see why.
By 1910, elliptical, tapered, variable wall thickness masts were usual on the big race boats. These masts were beautifully fabricated in steel. Similar spars were made for smaller boats in wood. It was the advent of extruded aluminium spars after WW2 that reduced the spar makers art to a simple taper at the top of an otherwise constant section and wall thickness. I think it was the prohibition on carbon spars in some of the earlier (1990s) Whitbread races that saw a return to fabricated rather than extruded aluminium masts. I remember hundred of parts being assembled to get the right weight, stiffness and moments at every part of each spar. They, of course, worked out much more expensive that the carbon spars that were banned.
Old 11-24-2010, 04:41 PM
philSweet's Avatar
philSweet philSweet is offline
Rep: 658 Posts: 621
I want one of those dogs!
Old 11-24-2010, 04:43 PM
Milan Milan is offline
Rep: 279 Posts: 320
Working boats rigs shapes, (as well as boats themselves), were result of multiple factors. Aside from material characteristics, limitations of available technology, local conditions, specialization for their specific trade, (low freeboard for hauling nets on some fishing boats for an example), there was one most important factor above everything else – economy - working boats were not built and sailed for fun. They had to provide daily bread. Therefore, they were always as simple and as economical to build, use and maintain as possible. Their sailors wouldn’t choose complicated solutions to achieve slight improvement in speed, (for much higher costs), if there was simpler, cheaper way, that worked almost as well.
Yachts on the other hand were toys of the rich man. They could afford complications and experimentations.
The most widely used rig type on the Dutch traditional sailing boats is a short gaff. It is a cheap, simple sail, with a long luff, (good for windward sailing), quite clean aerodynamically, much lighter then long gaff with a topmast.
Old 11-24-2010, 05:03 PM
gggGuest gggGuest is offline
Rep: 64 Posts: 396
What was the section on the built up masts in the 30's? Round or Oval? My ever failing memory tells me that as long as mast hoops were used, the luff section of the mast was round and constant OD.
Mostly oval, some pearshaped on a quick scan. Mast hoops had largely gone by then: they are of course not compatible with rigs with multiple cross trees because they won't pass the spreaders [grin]. The only time I see them in the books is on a gaff rig with a single set of cross trees at throat height.
Old 11-24-2010, 05:25 PM
RHough's Avatar
Retro Dude
LOL!
Okay. Lets revise this a bit.
Tapered masts are not unusual at all, they seem to be common.
Luff tracks and sliders allowed hoisting past spreaders.
Multiple spreaders are mainly so headsails can be have smaller sheeting angles.
We know that the RORC Rule favoured masthead rigs, we know that total area rules in development classes favour fractional rigs.
Is it fair to conclude that there is no reason other than economy to use a constant section mast?
Can a case be made for the masthead rig with constant section mast other than simple, cheap construction?
R
- Thomas A. Edison
Old 11-24-2010, 05:41 PM
Rep: 64 Posts: 396
As cases go simple, cheap construction is a pretty damn good one. There are quite a few applications in life for which that's a winner[grin]. But of course in a lot of situations fractionals are just as cheap and just as simple.
Old 11-24-2010, 06:28 PM
RHough's Avatar
Retro Dude
How about stating it very general design terms.
What are the drawbacks (if any) to using a constant section masthead rig on a production boat?
It is pretty well agreed that reducing pitch adds speed and comfort whilst sailing. The constant section masthead rig has a high centre of mass.
Same for roll.
Masts heavier than they need to be require heavier hull/deck structures.
Larger head sails require heavier, more expensive gear.
For racing a masthead rig requires a larger sail inventory and each sail is more expensive. (function of area) For cruising a single "medium size and weight" roller furled sail ends up with the boat motoring more often in light air. (trend towards larger engines and more tankage)
How far does the savings in structure, deck gear, sail inventory and auxiliary power go towards offsetting the added cost of a tapered mast?
Could tapered mast fractional rig boats be built to be price competitive with the boats with the cheap and simple masthead rigs we've seen for years?
It would seem that the relative ease of use and the (probably) kinder motion of a lighter fractional rigged boat would be just as important to the casual sailor and cruiser as it is to the racer.
Thoughts?
R
- Thomas A. Edison
  #25
Old 11-25-2010, 01:13 AM
Rep: 670 Posts: 2,457
If by narrow sheeting angle you implie a narrow shroud base then this is again controlled by material limitations. Enormous compression loading. Enormous strain on the hull.
Even now with modern materials the Mega sloops face engineering challenges. Think of Mirrabella V. 100 meter tall mast. Check out the sail technology needed to achieve this !
http://www.doylesuperyacht.com/mirabellav.htm
Height wise think how heavy traditional sail materials were. Not possible to humanly handle one big sail so they used two small sail. The weight aloft affected righting moment. The result was low aspect rigging , many masts and many sails. Need more power add another short mast. Nothing wrong with multiple masts..other than the huge windage they present.
As far as mast taper. Obviously less weight and windage in the high wind area aloft is the goal . A fractional can go extreme taper, a masthead rig, since it has all its gear on the masthead...halyards, stays..has to leave some real estate availble to mount it...the taper cant be so extreme...hence more widage and weight aloft for a masthead rig
Fiberglass constant camber Briggsm Multihulls 3 06-02-2010 03:44 PM
rotate a round section or a wing section ? simonfraser.97 Boat Design 3 11-11-2009 01:44 AM
Deadrise - Warp or Constant ? Nojjan Boat Design 0 03-10-2007 10:47 AM
Constant vs Variable Deadrise Marathon Boat Design 9 07-17-2006 05:21 PM
Crouch Constant Willallison Boat Design 19 02-26-2005 07:54 AM
