Old 05-07-2007, 10:51 AM
rd.sail rd.sail is offline
Rep: 10 Posts: 9
Choosing the right block
I have a Bristol 29.9 and I need to replace my mainsheet blocks. I have being looking for options and I have narrow it down to eather Harken or Lewmar. The system right now is a 4-1 mid boom. I was going to upagrade it to a 5-1 for my wife. Right now the main systems has and very old harkens and at some point the previouse owner replaced some of the block with ronstan.
I can use: Harken airblocks 57mm: 1 single, 1 Double and 1 double with becket. and 2 extra singles to lead the line aft. I could also use 75mm but that might be over kill.
For the lewmar, I would be the same set up but 60mm.
Here is my question. Which one should I used? Which is is a better block? I have being traing to find information only but I have not had many lock.
I would greatly appreciate any direction you can give me?
Old 05-07-2007, 12:12 PM
SeaSpark SeaSpark is offline
Rep: 96 Posts: 593
Harken
Harken considered superior to Lewmar by most experts, the term Harkenizing (upgrading hardware on a production boat to harken) exists.
Old 05-07-2007, 01:19 PM
Rep: 10 Posts: 9
Thanks you for the comment. I thought the same thing. I just need to check before a order all the parts.
Old 05-08-2007, 08:27 AM
LP's Avatar
LP LP is online now
Rep: 370 Posts: 639
Increasing the purchase ratio is also going to increase the sail pressure needed to move the boom, it will also increase the length of your sheet and also the weight of the sheets. (light airs consideration)
Just some thoughts.
LP
God bless the open minded people of the world. LP
Old 05-08-2007, 09:06 AM
Rep: 10 Posts: 9
Last year I replaced the main sheet, I was thinking then to increase the the ratio so I purchased a longer line and lighter sheet.
Question on you first part of your comment.(increasing sail pressure) Does this mean that there would be a larger force on the connection points on the sail (boom and traveller) so I would need to go to larger blocks?
I thought the force on the boom and traveller would be the same but it would take more line to sheet the boom. The effort should be less but longer.
One other thing I was thinking of doing is to rig it so when there is light air I can change the ratio to 4-1 instead of 5-1 by just reattaching the end of the line. I would deattached from the the traveller block (Double with becket) to a boom fitting.
Old 05-08-2007, 09:45 AM
Rep: 96 Posts: 593
sail pressure
LP must have been talking about the force needed to pull the sheet through the blocks. In light winds sometimes the sail does not deliver enough force to do this after a tack.
I think reattaching the mainsheet may prove a bit cumbersome when the wind increases.
Old 05-08-2007, 02:59 PM
LP's Avatar
LP LP is online now
Rep: 370 Posts: 639
SeaSpark was right. By increasing the purchase ratio, you increase the mechanical advantage of the sheet, but you are also decreasing the mechcanical advantage of the mainsail/boom. With free running blocks you may not see a difference or it may be negligible. Sounds like it's an easy switch so you can always go back if it doesn't work.
LP
Old 05-08-2007, 04:04 PM
Rep: 10 Posts: 9
Thanks for all the comments. I'm not too worry about very light air becuase that's when my engine comes on. My boat does not like light air anyway.
It also would be very easy to go back to 4-1 with the same blocks I just need to change the placement.
I guess my last concern is if the Hark carbon 57mm will handle the load. From comparing the stats they will. Does anyone think I should go to the 75mm?
Old 05-10-2007, 10:35 AM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 338
Different approach here..
On my machine I run a Ronstan (sp?) 4/8:1 It has a double line coming through a double camcleat. Pull both and you have 4:1 drop one and you get 8:1.
The mainsheet is actually a big loop. When you install it you have to splice the line togather. (I had mine done professonally 'cause I don't know how to do fancy splices like that.)
I really love it though.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 05-10-2007, 11:17 AM
Rep: 10 Posts: 9
Jim,
I'm trying to use the same set up that I had before. My line goes to a dedicated winch. So the cam cleat will just add another level of difficulty for my wife. We have a 5 year old so keeping the systems on the simple is a must for us.
On another note, I contact a techitian at Harken. He recomended to go with the 75mm carbo blocks instead of the 57mm. The blocks will have a greater life that way. I'm going to follow his advice.
Big block or Small block? Verytricky Inboards 15 10-10-2007 01:04 PM
Help choosing first boat to build reaver777 Wooden Boat Building and Restoration 4 07-07-2006 10:41 PM
Choosing a anchor and winch jmac Metal Boat Building 12 05-04-2006 07:16 AM
Can you help me choosing an engine? neovalk Fiberglass and Composite Boat Building 3 11-16-2005 02:24 PM
Can you help me choosing an engine? neovalk Fiberglass and Composite Boat Building 4 11-04-2005 02:24 PM
