Old 07-04-2004, 07:10 PM
Willallison's Avatar
Rep: 2280 Posts: 3,467
Centre of Lateral Resistance
In order to calculate lead, I need to determine the centre of lateral resistance.
Both computer programs that I have give (amongst much other stuff!) the centre(s) of the wetted surface.....same thing ??
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 07-04-2004, 10:10 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
same thing ??
Nope! Probalby close, but.... If you "draw a line" around the underbody (or project to Cplane), and find the centre of that area, it is usually taken as good enough. I tend to use 50% only of the rudder, and ignore the roach, or full rudder and full roach, just to even things out.
Steve
Old 07-04-2004, 10:31 PM
Thanks Steve....as usual, quite elementary.
Will
www.imaginocean.net
Old 07-05-2004, 12:38 AM
der hang on a tick - not so elementary after all....
You're talking Rhino.....and I do have that, but to say that I've mastered using it would be a GROSS overstatement! Can you do the same thing in AutoCad? (I had to draw criss-cross lines the old-fashioned way to find the CE, so finding the centre of the sail(s) would be handy too....) I've sent a 2D dxf file to AutoCad with the preliminary sailplan....
Will
www.imaginocean.net
Old 07-05-2004, 01:45 PM
SailDesign's Avatar
Will,
In autocad, draw a line around the bottom (i.e. make the underbody a closed polyline) then make it a region (you know, type "region", select closed underbody poly, hit "enter" or space as preferred), then type "massprop", "L" for "last", and return. It will give you a nice little pop-up with more info than you could ever use, but will have centre of Area listed. And Bob's your uncle/father/ distant cousin, whatever.
Steve "let me know if you can't understand that"
Old 07-05-2004, 08:04 PM
Aha!!....region....I've been trying to figure how to make the massprop feature work, when I've tried before its always come up with no object selected or some other such message......as always....thanks Steve!!
Will
www.imaginocean.net
Old 07-06-2004, 07:06 AM
SailDesign's Avatar
Hth
Old 07-06-2004, 08:37 PM
Chris Krumm Chris Krumm is offline
Registered
Rep: 10 Posts: 92
Steve -
When finding center of lateral resistance, do you ever "weight" areas of the underbody and appendages differently to account for differences in efficiency in lift generation from the foils vs. the canoe body? Would you calculate CLR differently for a traditional, full keel vessel than for a "skimming dish" with a hi-aspect ratio keel? Just curious about methods...
Chris Krumm
Old 07-06-2004, 09:22 PM
SailDesign's Avatar
Chris,
"No" would be the short answer. But "Yes" in some ways.
I don't weight the areas, except as stated above for roach/no roach. The amount of klead applied does vary, though, which amounts to the same thing. 10% for masthead, 5% for fractional (7/8 or below).
So, no, I wouldn't calculate CLR any differently, but the lead would vary. How much for a traditional full-keel boat? Dunno yet... No-one has asked recemtly, but I would probably defer to Skene's, Chapelle or Dixon Kemp for that one.
Steve
Old 07-07-2004, 10:25 AM
SeaDrive SeaDrive is offline
Rep: 15 Posts: 223
There is a method for fin keel yachts in Larsson & Eliasson's Principles of Yacht Design.
Old 08-13-2004, 07:19 AM
Rep: 66 Posts: 640
Steve,
Can you explain "roach", my dictionary gives me either 'type of bug' or 'type of fish'. I suppose naval terms not included.
Peter
Old 08-13-2004, 10:29 AM
redcoopers's Avatar
redcoopers redcoopers is offline
Member
Rep: 40 Posts: 54
In the case of a marconi-rigged mainsail, roach is the extra sail area on the leach - the part of the sail most supported by battens.
An IACC boat has a huge amount of roach.
If you have no roach, your mainsail would simply be a triangle. A Chesapeake bay skipjack has no roach.
Old 08-13-2004, 10:42 AM
Rep: 66 Posts: 640
Thanks, Redcoopers.
Peter
Old 08-13-2004, 04:26 PM
Rep: 309 Posts: 589
John Leather, Howard Chappelle, Herreshoff, and an old copy of
Skenes all discuss the topic of lead on different traditional hulls and rigs.
Old 08-13-2004, 05:00 PM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 389 Posts: 507
And - as always - so does Larsson & Eliasson in "Principles of Yacht Design".
I have an idea: How about contacting the publishers and ask for a donation to this great website? I mean, I cannot count the times this book has been recommended here...
That's all for now - back to the (hopefully peaceful) Olympics!
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
center of lateral resistance Guest Sailboats 51 12-05-2005 04:07 AM
Wetted surface area - approximate formulas Mike D Boat Design 11 08-25-2005 12:00 PM
why canting keel? freemanjunelee Sailboats 18 06-06-2005 05:37 PM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-26-2002 12:26 AM
