#46
5 deg = 0.087 rad. Cla * a = 0.54 As a practical matter, the lift curve slope is closer to 0.1 due to boundary layer displacement. And don't confuse the two-dimensional lift curve slope with the angle of attack required for a three-dimensional planform. Considerably more angle of attack is needed to reach the same level of lift. The apparent lift curve slope of planform is closer to a = a0 / (1 + a0 * 57.3 / (pi * AR * e)) a = 3D lift curve slope, per deg a0 = 2D lift curve slope, per deg AR = aspect ratio e = Oswald efficiency factor
#47
What is 57.3? I've been using .7-.8 for value of e, is that "close enough" for a sailboat? -Randy |
#48
| 57.3 = 180 / pi Conversion from degrees to radians. Anders M |
#49
| I was just too quick to copy paste some formula... |
#50
| So is that where all you rocket scientists get your formulas, copying and pasting? For a while there I thought you all Knew and understood these formulas? Silly me. |
#51
| No no Chandler don´t confuse egineers with scientists. ![]() |
#52
| Sorry again, Chandler :-) One thing is copy/paste or look up in a reference. The most embarrassing is not to check the answer, is it reasonable. When dynamic pressure is 0.5xROxV^2, it is not reasonable to have a lift coefficient much larger than 0.5... |
| Wetted surface area - approximate formulas | Mike D | Boat Design | 11 | 08-25-2005 11:00 AM |
| The Concept Catamaran Project | Duane Mc | Boat Design | 63 | 08-14-2005 07:34 PM |
| Self Righting Rig | Wardi | Sailboats | 14 | 06-29-2005 01:03 PM |
| Centre of Lateral Resistance | Willallison | Sailboats | 15 | 08-15-2004 03:52 PM |
| Wetted surface area II: Cat hulls or Monos? | Mike D | Boat Design | 1 | 09-25-2002 11:26 PM |
