Old 09-08-2004, 04:35 AM
Slowmo Slowmo is offline
Registered
Rep: 10 Posts: 38
CE vs. CLA in a dynamic reality
This is a very interesting design problem.
1. If planing Lateral area is down to zero in the front of the hull and CL moves backwards.
2. In waves the hull moves, the mast angle changes and CE chages in seconds.
Can these things be universally solved... or as in most cases dramatical trade offs needed!?
We dont like to flipp the rudder forth and back all the time, do we!? Some stability needed.
For sailers going high in head wind it's said thay should have a high rigg and a deep keel (small ratio depth /corda for both sail and centerboard).
But...
with a high rigg CE moves more in waves.
with a deep keel (small corda) the CE moves even out of the physical lateral area.
Are there any guiding rules or any old wisedom here?
Old 09-08-2004, 04:41 AM
Rep: 66 Posts: 640
Yes, these items are discussed in "Seaworthiness, the forgotten factor" - C.A. Marchaj.
I just finished it, and it's interesting reading!
Dutch Peter
Old 09-08-2004, 05:41 AM
Rep: 1623 Posts: 2,343
Dutch Peter
Not just interesting....That book should be mandatory reading for every aspiring designer. As an engineer I find all Marchaj's work satisfying.
Mike Johns.
Old 09-08-2004, 06:01 AM
Rep: 66 Posts: 640
Originally Posted by MikeJohns
Dutch Peter
Got halfway "sailperformance", and "hydrodynamics" is still on the "to-buy/birthday present" list. To me they're bibles, like Skene, Chapelle and "principals of....". Must be that English is not my native tongue that that didn't come across.
Dutch Peter
CE: Through-hull fittings on aluminum boats Eric Sponberg Metal Boat Building 2 04-05-2005 11:21 PM
CE: Through-hull fittings on aluminum boats Eric Sponberg Boat Design 7 04-05-2005 09:06 PM
