  #106
Old 02-02-2005, 03:35 PM
Doug Lord
Skandia
Thanks, Nico; its so very sad to see a great boat-any boat- like that....
  #107
Old 02-02-2005, 03:36 PM
usa2's Avatar
usa2 usa2 is offline
Rep: 11 Posts: 538
skandia originally didnt have that daggerboard, or the bowsprit. They were added after the boat was first trialed and the daggerboard reduces the leeway suffered while reaching. The bowsprit was added after they realized the boat went so fast that symmetrical spinnakers were slower in nearly all wind conditions. I wonder why Skandia was first conceived without the daggerboard?
  #108
Old 02-02-2005, 03:46 PM
Doug Lord
Skandia
Either for the same reason as Mari Cha -water ballast upwind(I'm not even sure Skandia has waterballast) or to save money: CBTFco charges around 5% of the final finished cost of the boat as a royalty-but they provide a huge amount of technical assistance to the designer/builder.
If you're going to go upwind with a canting keel boat- and use the keel up wind- you will have extra lateral resistance or you won't perform. Mari Cha was designed to use water ballast upwind canting the keel offwind-never both at the same time so she has no board.
  #109
Old 02-02-2005, 06:11 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
I have received a full report about Nicorette's building - she was designed by the Simonis/De Voogt studio's (one in SA and one in Holland). This was published in the Dutch Magazine "Zeil" (Sailing).
For a number of practic reasons, old Nicorette was butchered up and gave her deck and other hardware, costly hardware, to the new hull and keel.
Ok, I have learned again something, the canting keel, in whatever execution plays an eminent role in the new designs, the new designs to come in the high end racing circuit.
That Skandia was a budget ship might be true, the same counted for Nicorette, according to the article. She was built by a group of wandering spe******ts (?) and just finished before the S-H began. In a light breeze a piece of hardware broke and caused a rip in the mast of considerable length. Repaired, it hold in the race.
Bit by bit it becomes clear that the distinction between the regualr yacht and the racing yachts are bigger and bigger.
  #110
Old 02-02-2005, 08:49 PM
usa2's Avatar
Rep: 11 Posts: 538
Skandia has no water ballast. Nicorette used the 80 footers deck and hardware because they wanted it read for the 2004 Sydney Hobart Race. You would think that the lateral resistance would matter a lot when beam and close reaching though, wouldnt you?(when you are going with the canting keel and no board)
  #111
Old 02-02-2005, 10:14 PM
brian eiland's Avatar
Rep: 1503 Posts: 2,648
Originally Posted by Lorsail
Brian, I can't seem to find any mention of it; do you have reason to believe that this boat is CBTF?
Sorry Lorsail, I think I didn't look closely enough at this subject matter to deferentiate between CBTF and just canting keels. Guess I posted my comments in the wrong thread.
RunningTideYachts.com
Distinctive Expedition Yachts
  #112
Old 02-02-2005, 10:28 PM
Doug Lord
right or wrong thread?
Brian, there is no right or wrong thread as far as I'm concerned; I was curious-thought you might have some insight or info I hadn't found...
  #113
Old 02-04-2005, 05:03 PM
usa2's Avatar
Rep: 11 Posts: 538
is the new Alfa Romeo a CBTF boat?
  #114
Old 02-04-2005, 05:09 PM
Doug Lord
no idea
no idea
  #115
Old 02-07-2005, 02:28 PM
Reichel-Pugh
In Yachtforums I saw a rendering of a maxi using CBTF, is this true, or did I take it wrong?
  #116
Old 02-07-2005, 02:33 PM
Doug Lord
maxi CBTF
Lots of maxis using CBTF including the two R/P z86's, Maiden Hong Kong and -I think- Genuine Risk(not positive).
Got a link to "Yachtforums"?
  #117
Old 02-07-2005, 02:39 PM
Link to YachtForums
.... Got a link to "Yachtforums"?
Link to YachtForums:http://www.yachtforums.com/forums/index.php
  #118
Old 02-07-2005, 02:46 PM
I commented on it - with what I learned through boatdesing.net keeping in mind. Also my own observations, of course.
I have been walking around in that scene for a few years and out of curiosity I joined that forum. A few members from this forum join Yachtforums as well, or it is maybe the other way round. It's a bit tricky forum because of the fact that commercial issues play a prominent role there.
Have a look, it will not be difficult to find - it is in "breakthru hulls"
  #119
Old 02-07-2005, 03:07 PM
usa2's Avatar
Rep: 11 Posts: 538
genuine risk uses the cbtf concept. the designer may have modified it slightly to avoid paying the CBTFCo fee though......
  #120
Old 02-07-2005, 03:08 PM
Doug Lord
yachtforums
I registered and looked and looked. Couldn't find any "breakthru" category; any more hints?
Foiler Design tspeer Sailboats 1031 12-17-2010 02:38 AM
TP52s mighetto Sailboats 2052 09-06-2007 11:46 AM
25' trailer sailer LP Sailboats 44 09-02-2005 09:24 PM
Foil dynamics questions. kenwstr Boat Design 2 03-11-2005 02:37 AM
Long cruising keel foil shapes MikeJohns Boat Design 30 11-14-2004 02:35 PM
