| Carbon bowsprit kits Anyone know of a kit available which mounts the pole through the hull side like the Melges and J boats? There are lots of deck mounted kits out there but i have yet to locate one for internal mounting. Steve |
When I did mine I opted for the deck mount to my own design. Less water intrusion below. |
| Thanks Paul,that exactly what i am after except for a larger size to fit a 35 ft boat for a customer,we can of course do a custom job but i had heard that such a fitting was available as a kit but have been unable to locate one yet. On my sons boat we did an articulating sprit through the bow which is way cool but not really worth the effort,sometimes we tend to do things just because we can. Steve. |
| Will do. |
| I would be suprised if it is possible to make something like this as a kit. Asymetrical poles induce tremedouse side and vertical loads on a boat, and need pretty serious engineering work to be installed as a modification, at least if you don't want to rip the bow off the boat in heavy air. If you are seriously considering this, particularly if you are performing the work professionally I would retain an engineer to work out the loading first.
| did you ever find parts for your project?? I currently added a bowsprit to a c&c 110 at work and might be able to give a little advice I have considered making some moulds for the side covers Jeff |
| I built one into my boat. I can pick up the bow with it perhaps even shoot cannon balls. But being a multi hull I know that if / when I stick my bow in a wave or in the water I should keep the front of the boat where it belongs. |
| racing bowsprit | jakers | Sailboats | 3 | 01-01-2010 06:14 AM |
| Bowsprit alignment | zulpas | Boatbuilding | 4 | 09-06-2009 01:58 PM |
| BowSprit | Butch .H | Sailboats | 10 | 10-26-2008 03:23 PM |
| Bowsprit design | LP | Boat Design | 2 | 04-04-2007 09:25 AM |
| Carbon Fiber Mast/pushpole Kits | JR-Shine | Marketplace | 0 | 07-13-2004 10:07 AM |
