Old 09-29-2004, 12:45 PM
seamonkey seamonkey is offline
Registered
Rep: 10 Posts: 40
canting keels...
as a dinghy racer,,I've never particularly liked healing...and don't feel it's really very efficient,,,I guess others would agree,since canting keels now seem to be entering the high-perf sailboat scene with gusto!
How do these work.....any links to view make-up,,,pictures,,,,designs.??....thanks!
Old 09-29-2004, 08:08 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
SeaMonkey,
I have to ask, are you really a Brine Shrimp? (If in doubt as to whether that was an insult - No, it wasn't)
CAnting keels are not really there to "stop" heeling, but to provide more Righting Moment. All that means is that you can carry more sail for the same angle of heel. As far as efficiency goes, many boats (especailly the fat/flat Open class boats, actually sail faster with more heel, since their waterlines get narrower as they heel.
Pictures, etc? Well, I don't have a thousand words, but I'll try. Imagine a keel fin that comes inside the boat, with a large pin/hinge aligned with the bottom. At the top of this fin (let's say 3 feet above the hinge), there will be a hydraulic cylinder or a block and tackle, depending on the size and weight of the keel, which will be able to swing the keel from side to side.
Simple, non?
Steve
Old 09-29-2004, 09:50 PM
Registered
Rep: 10 Posts: 40
........just add water ,,,it comes alive!!!
yeh,,,I understand the 'keelboat dynamic' ,but rather not heel!
Yes I imagined the general layout you describe,,,but there must also be some form of gasket,or sealing to prevent the ocean from finding it's way into the boat!?
Old 09-30-2004, 07:57 AM
yachtie2k4 yachtie2k4 is offline
Anarchist
Rep: 32 Posts: 51
they use compressed air to stop the water coming into the boat
I see said the blind man to the crippled nudist who put his hands in his pockets and promptly walked away
Old 09-30-2004, 11:27 AM
Registered
Rep: 10 Posts: 40
.......but seriously,,,,,folks...........!
Old 09-30-2004, 12:29 PM
SailDesign's Avatar
The mechanism goes in a big triangular box with a lid. Takes space, but if the top is above waterline, you can pop the lid for repairs underway, and still stay dry
Steve
Old 09-30-2004, 01:07 PM
Registered
Rep: 10 Posts: 40
hummm--nasty space-taker,,,and a fair volume of H2o in that 'V' ,I'd imagine.--any detail shots or drawings to be found of the box/hinge mechanism/etc?--then I can ask less silly questions!!
Old 09-30-2004, 05:57 PM
Anarchist
Rep: 32 Posts: 51
they use compressedair on skandia to keep the water out. its not ********, i know this cause the boats from my yacht club
Old 09-30-2004, 06:34 PM
Doug Lord
canting keels
Check out post #9 under this thead:
Swing keels?
There are all kinds of ways to seal a canting keel .Among the most effective uses a sort of module into which the keel is inserted. A portion of the module extends forward or aft thru watertite seals to allow a lever to be attached to rotate the keel manually, hydraulically or electrically. Simon Rogers has an excellent patented design that allows the canting keel to retract as well as move fore and aft; this is a real plus on the Mini's this system was first used on. Some systems have a slight disadvantage from a wetted surface perspective in that they have a "bump" on the bottom to allow room for the keel to pivot; other designs have eliminated this bump.
But as I mentioned in the post referenced above the MOST important consideration in using a canting keel is the type of extra lateral resistance you will use as the keel cants.. My favorites: CBTF for performance. kFOIL for room in the boat in cruising applications or on boats where upwind work is not at a premium.
Last edited by Doug Lord : 09-30-2004 at 07:42 PM. Reason: to correct screwed up sentence
Old 10-02-2004, 10:13 PM
Registered
Rep: 10 Posts: 40
..........any chance you can sneak in there and take a few pictures?--that'd be worth many 1000's of words!!.........cheers!
Old 10-04-2004, 10:41 AM
Anarchist
Rep: 32 Posts: 51
mm, not really, as skandia is going over to asia & i'm hopefully movin up to new south wales & will probably be up in new south wales before skandia gets back to the club, so, no there is no chance, but i assure you that is how they do it.
Old 10-06-2004, 01:44 PM
Registered
Rep: 10 Posts: 40
well-it would sure be great to see any pics/drawing links available!!.......thanks
Old 10-06-2004, 11:13 PM
Anarchist
Rep: 32 Posts: 51
i can give you their website, but its being "repaired" which has been goin on for ages, www.wildthingyachting.com.au
Old 10-07-2004, 12:00 PM
dougfrolich dougfrolich is offline
Rep: 140 Posts: 559
This is a setup I used for my Pac30 design
Old 10-07-2004, 02:09 PM
Doug Lord
Canting keel "module"
Simply fantastic-great design!
Canting Keels In Production Yachts D'ARTOIS Sailboats 169 02-17-2006 06:06 PM
canting keels: how are they displaced from side to side? Thaddeus Boat Design 5 10-02-2005 05:22 PM
technical papers or publications on canting keels danwupperman Boat Design 1 03-15-2005 07:28 PM
papers or publicatios on canting keels danwupperman Open Discussion: All Things Boats & Boating 0 03-14-2005 07:30 PM
canting keels and all that dionysis Boat Design 44 11-12-2004 03:04 AM
