| The foils I showed from BackmanBoats are not adjustable. ON the 21'er it's canted, on the 29'er it's canted and the fins on the bulb adjusted. |
| canting trunk Thanks again guys. I'm going to relook at the "V" trunk volume and it's effect on self righting after the thing gets knocked down. It shouldn't hold any water but I'm going to doublecheck. |
| This one lifts and cants. |
| lift +cant Doug, thanks! Can you go into anymore detail? I'm having trouble understanding how the lift function works. Does whatever lifts the keel disengage as the keel cants? |
| http://www.cariboni-italy.com The keel can be lifted when it is in the vertical position. The vertical ram does the lifting, a carrige is engaged by two pins to lift the keel, and are actuated hydraulically. |
| cant + lift I appreciate the info -thanks again! |
| Canting Keel Mechanisms | SuperPiper | Sailboats | 88 | 01-05-2007 02:58 AM |
| Canting keel | tamkvaitis | Sailboats | 3 | 01-08-2006 08:03 PM |
| why canting keel? | freemanjunelee | Sailboats | 18 | 06-06-2005 04:37 PM |
| Canting Keel Design | MrK | Sailboats | 28 | 03-19-2005 07:22 AM |
| Combination CB trunk / Motor well | wwheeler | Wooden Boat Building and Restoration | 14 | 04-05-2004 09:05 PM |
