Old 01-08-2006, 09:36 AM
tamkvaitis tamkvaitis is offline
sailor/amateur designer
Rep: 34 Posts: 131
Canting keel
Is it posible to make canting controls by using ropes and blocks? I am thinking about 100 kg of torpedo weight.
Lithuania
Old 01-08-2006, 10:04 AM
Doug Lord
Canting Keels
Absolutely, yes. Boats such as mini 6.5's, Bethwaites 26 footer, the Backman 21 and others do exactly that.
Old 01-08-2006, 08:44 PM
yankee yankee is offline
cantering keels with a little hev ho
Sure it can be done, open 30's use that system and our keel weight is around 700 kg/1550lbs.
I've heard it being used on open 50's
Of course I don't recomend mico blocks to do it.
Old 01-08-2006, 09:03 PM
usa2's Avatar
usa2 usa2 is offline
Rep: 11 Posts: 538
I believe certain open 60's have done that too. on big boats it takes a while to get it over if done manually but on a small boat you could probably do it quite quickly using a block and tackle arrangement.
what came first the keel or the boat? jackason Sailboats 8 11-30-2005 09:33 AM
Canting Keel reactions @ Cylinder connection!! GuestR01312011 Boat Design 7 10-30-2005 08:56 AM
Winged Canting Keel for Increased Efficiency??? sailingsloofer Boat Design 1 08-30-2005 01:16 PM
HELP ! Canting keel for 28ft performance daysailer Guest Jan Boat Design 10 12-03-2003 12:07 PM
