Old 07-14-2010, 09:34 PM
smtoole's Avatar
smtoole smtoole is offline
Snipe #9371
Rep: 63 Posts: 11
Can a 40 year old wooden Snipe be competitive?
Hi - new to the forum, first post. Just obtained a 1971 15.5' Snipe, hull #9371. It's all wooden including the mast and boom, and I'm restoring it in my garage. Eventually I'd like to get into using it competitively. My question is whether or not it can really be competitive against today's fiberglass models. Should I even try to get the boat in shape to compete or should I restore it to a more classic look with original winches, etc.? I don't mind the classical look if it's simply not going to be competitive, but if it has a chance competitively, I'd get more fun out of it by giving it what it needs in terms of hardware and rigging.
Love to get input from the forum, as well as anyone who has experience restoring an old snipe. I also have questions about that but I'll save that for a different post.
Thanks, looking forward to the interaction.
Old 07-14-2010, 10:06 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,604
The answer is that yes it can be competitive. Here is something you may have seen: http://www.snipe.org/index.php?optio...id=24&Itemid=1
Don't hesitate to contact the Snipe guys thru the website.....
yes, it is a revolution
Old 07-14-2010, 10:53 PM
smtoole's Avatar
Snipe #9371
Rep: 63 Posts: 11
Thanks - inspiring article!
Thanks for passing this along. I actually hadn't seen that article yet, so much appreciated!
Old 07-15-2010, 11:46 AM
Rep: 1493 Posts: 7,447
Yes it can be very competitive. However, with that number it is early sixties.
Old 07-15-2010, 04:54 PM
Briggsm Briggsm is offline
Rep: 10 Posts: 17
If it is an early cedar planked snipe probably not, if it is plywood maybe. I had a friend who had a Cedar snipe and an early 80's Mcglaughlin boat, both were equipped to modern standards and he told me the foam boat was a good bit faster. The South American plywood boats were built with sapele, gaboon and mahogany plywood and the US boats were mostly of doug fir. I owned a doug fir Y-Flyer which was Heavier than its gaboon counter parts but seemed equally as fast. The doug fir was harder to maintain a good finish on because it was constantly checking under the glass.
If I were you I'd fix it up with the bare minimum go fast such as pusher/puller and head stay tension. If it seems like the boat has moments of speed on the course go all out, if not go find some pretty bronze hardware.
Peace Briggs
Old 07-15-2010, 06:16 PM
Paul B Paul B is offline
Rep: 15 Posts: 1,770
The first thing to do is weigh the boat. Depending on how close it is to min weight will tell you how much work it would be to get it to anywhere near a competitive boat. You may have to rebuild a good part of the boat to get where you need to be regarding weight and stiffness.
Do you know what the construction method was? That would also be a major indicator. Regardless, the shape may not be a "fast" shape, and therefore nothing would make it competitive in a competitive fleet.
Finally, your wood rig would have to be replaced with a modern rig if you have any ideas about racing the boat. That is a big expense.
Back when Snipes were big around here in the late 70s and early 80s the Phoenix Snipe (foam/glass) came out and if you didn't have one of them you were not going to be competitive with the fast guys.
Old 07-15-2010, 11:45 PM
smtoole's Avatar
Snipe #9371
Rep: 63 Posts: 11
Great feedback, thanks!
Lots of really good comments, thank you all so much. I thought I'd post some pictures to shed some light on the topic. Let me know if you see anything that jumps out at any of you. She's a work in progress so try to look past the cosmetics.
Here are a few more photos: http://picasaweb.google.com/HerndonD...eat=directlink
I welcome any insights about some of the deck damage as well as the hull cracks in terms of the best way to repair these. I'm new to boat restoration.
Old 07-16-2010, 08:03 AM
smtoole's Avatar
Snipe #9371
Rep: 63 Posts: 11
Here's a deck shot
After I removed all the deck paint.
Old 07-17-2010, 10:14 AM
The first thing to do is to change the deck to the large cockpit opening and new frame design. You can get all that from SCIRA
how do i make a kick-up rudder for my snipe fercammo Sailboats 13 10-28-2011 06:51 AM
1947 Snipe Woody Restoration mrector Wooden Boat Building and Restoration 11 05-09-2011 07:00 PM
Yacht Design Services at Competitive Fees yachtdesigner Services & Employment 1 08-31-2005 09:46 PM
Snipe plans Ivandro Sailboats 1 07-05-2004 09:03 PM
Need competitive boatbuilder (yard) for your project? Guest Services & Employment 0 12-04-2003 05:20 AM
