| Cal 20 Hull fairing question I would like to gain a modest windward ability in my Cal 20. The existing keel is approx 950 pounds, 7/8" thick, and the length above the bulb is 42 1/2". Whole boat draws 3' 5" so the flat height above the bulb is about 24 to 28". I've looked at some of the hull threads and realize there are tradeoffs, lift vs drag. From the attached graphs, a profile like 12% Joukowski looks like a good choice if I'm reading them correctly. Another possibility is to just shape the leading edge to something like NACA0004 and fair the rest of the keel smooth. Your comments are most welcome! Chris B |
From the class rules: KEEL: The leading and trailing edges of the mounting flange may be faired into the hull. A .25 inch fillet is allowed between the sides of the flange and the hull. The vertical fin may not be altered from the original factory profile. It may be faired, but the maximum thickness shall not exceed 1.5 inches. Maximum profile cord lengths: 6 inches down from flange: 49.750 inches 12 inches down from flange: 47.750 inches 18 inches down from flange: 45.625 inches. The bulb may be faired but not altered in shape. |
| Hi Paul, I've rescued the boat from the scrap heap and I'm not concerned about re-sale value. I'm also aware of the class rules, but am still wondering if anyone has a comment on attached profiles for a boat with ablative hull paint at speeds in the five to six knot range. Thank you. |
I wonder how you will be able to thin out the existing iron to match with the sections these foils? |
| Multi-hull construction in So Cal | sailsocal | Boatbuilding | 0 | 10-14-2009 01:00 AM |
| Hull Fairing Question | bjviking | Fiberglass and Composite Boat Building | 4 | 10-12-2009 11:12 AM |
| A fairing question | missinginaction | Wooden Boat Building and Restoration | 1 | 09-05-2009 01:51 PM |
| Fairing a hull | tuantom | Powerboats | 15 | 06-23-2008 03:38 AM |
| Fiberglass Fairing Material Question | Hellkell | Fiberglass and Composite Boat Building | 3 | 08-25-2007 07:46 PM |
