Old 10-25-2007, 10:23 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Bridge-deck clearance yet again
Bridge-deck clearance is a major factor seperating the inshore catamarans from the off-shore catamarans. Anything less than 3' of clearance from the bottom of the deck to the water between the hulls would not be well-suited for off-shore use.
Someone's comments off a thread -
I've now read enough posts / articles /comments to believe one want to make the clearance at least a couple of meters It does seem a bit unrealistic and top heavy though. Besides it won't be much fun climbing down a ladder to get a fish out the water - be a bit like fishing from an empty cargo carrier's deck
Since I'm a novice wrt catamaran's, common sence tells me if most of the weight is kept in the floating hull's a catamaran is less likely to become top heavy ? but it may look less atractive when 'boxy' ? when you lift the cabin some or am I missing something ?
What is the ideal height without pushing your luck on the one end or being rediculous on the other ?
It seems most of the catamaran's with a 1m clearance scores high points. Looking at some really large vessels some of their clearances are very small if you take their size in consideration. It seems only small catamarans that should have a low-ish bridge deck clearance so they won't tend to roll over naturally.
What are the design cryteria around this ?
Regards
Fanie
Water ! Just gimme water !
Old 10-25-2007, 09:52 PM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,322
Allow me to point you in the direction of some information beyond what I read somewhere that 10 to 15% of beam gives an idea of a displacement hull capable of handling open waters.
Ribin Chamberlain (living in Tasmania Australia), Roger Hill, NZ, Crowther Designs, Kanga Birtles, Schionningdesigns.com.au, Malcolm Tennant and many more - google these to start & ask by email?
Old 10-26-2007, 03:45 AM
Fanie's Avatar
Fanie
If I have to e-mail the boat builders it makes this forum obsolete. Besides, each of them will only tell you what their boat clearences are.
I was hoping someone with experience would offer some comments. For instance if your deck clearance is 700mm do you consider it too low, occadional deck slap, or great it never touches.
Regards
Fanie
Old 10-26-2007, 04:03 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,518
It will always touch . Its a case of touch a lot or touch a little bit. My cats bows must 6 feet and I have had green water over them in small squalls. I think there is no escaping this.
I dont know what my clearance is but I can go under there with the dinghy and the engine still on,--so probably 600/700mm.
Sorry not much help, but you will always get bridge deck slamming.
Old 10-26-2007, 04:49 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
Gunboat 62 Finest kind!
http://www.southwindssailing.com/art...206/tribe.html
http://www.morrellimelvin.com/sailbo...2-Gunboat.html
http://uncutvideo.aol.com/videos/cab...b7fcdf0dd91825
http://www.deltayachtsbrokerage.com/...unboat-en.html
http://www.google.co.uk/search?clien...=Google+Search
Pericles
1947 Monk Bridge Deck Cruiser johnjohn Powerboats 2 01-19-2007 03:43 AM
Clearance under a bridge solidovale Boat Design 2 07-31-2006 01:58 PM
Dimension of seats and feet clearance jfblouin Boat Design 3 03-28-2006 03:51 AM
sterndrive, clearance Danielsan Boat Design 4 09-25-2005 10:03 PM
Roach to backstay clearance des Sailboats 1 06-30-2004 07:41 AM
