| BowSprit I have a awful bowsprit arrangement on my boat(not a yacht just yet).I think it was designed and fitted by the Mad Hatter.I would like to change this arangment to somthing more becoming the old girl.Thanking you all in advance
__________________ If all else fails hit it with a hammer |
| Could you post a side view, some explanation of what you have now, info on boat especially? There are just a few important criteria for bowsprits. The heel must be treated exactly as a sideways mast step. That means a very strong support base. A samson post is traditional. The whisker stays should be below the line of the sprit so that even if the bobstay goes, the whisker stays will function to prevent the sprit bending up. Spruce or fir are best for low weight. A solid rod bobstay of stainless or bronze won't chafe an anchor rode as much as chain or wire. Just iodeas I've used. Alan |
| look at the old gaffers pages some really good ideas http://www.2oldgitsinaboat.co.uk/ima...lery/index.htm http://www.eastcoastclassics.co.uk/blogs.htm enjoy |
| here is a bit that will keep you out of mischief for a day or three http://www.eastcoastclassics.co.uk/links.htm |
| Thanks Manie.
| hi every body i m ready to give free plans and body lines drawing of different ships and get plans in return. |
| Alan I have had a look at the structure of the forward parts of the boat and have found no indication of any re-enforced areas adapted for the mounting of a bowsprit.The one in the photo was mounted using four 12mm stainless steel thread bars through 18 mm pine. The pine is about 1m2 and bolted to the frame work(2). I have found very little evidence that this type of boat(Estlander) was ever designed to have a bowsprit.(Manie dont buy one you can have this one). I am going to omit this bowsprit during the re-build no evidence of attachment points for rigging or sail. Thanks Butch
| naserrishehri what boats have you got in mind.
| Hi Butch.H rather than a fixed bowsprit, you may want to look at a reeving bowsprit supported by a sampson post or bitts on the inboard end, a ring arttached to the forestay tang and a bobstay. You would also need tackles on the outer forestay and bobstay to provide tension when in the deployed condition. This offers some advantages in that the slip length is only the hull length so no additional marina fees, you can adjust the length quite easily just by cutting the bowsprit down or getting a longer pole. The structure required is simpler and easier to design and construct. All the best with the project. David |
| Thanks David food for thought
| bowsprit redesign | sw44 | Wooden Boat Building and Restoration | 5 | 01-13-2008 03:37 PM |
| Retractable Bowsprit 35 foot sports boat | robbo007 | Sailboats | 10 | 11-04-2007 05:51 PM |
| Bowsprit design | LP | Boat Design | 2 | 04-04-2007 10:25 AM |
