| Bow sprit in high seas. I'm looking for stories or opinions about bowsprits and their effects during heavy weather (high sea states). Does anyone have experience with bow sprits getting buried in waves and causing damage to a vessel? Last edited by Shack : 10-12-2009 at 08:57 PM. Reason: typo |
| I've never heard of such a thing, but I guess that is an argument for the spar-style bowsprit, as opposed to a platform-type. It's hard to imagine a spar-type breaking by a wave, but I suppose a platform-type could take quite a pounding. -- John ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Check out my blog: http://unlikelyboatbuilder.com ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
| I have been submerged more than once working out in the bowsprit. There isn't usually problems with the boat but with crewmembers getting washed off.
__________________ Gonzo |
| If you are burying your bowsprit in solid water, you are probably shipping green water on your decks as well. If that is the case, the sprit may be further down on your list of worries! |
| Not for the bowman
| Is there a benefit in having a bowsprit in such conditions? For example, ability to carry sail further forward.
| slower recovery? Two boats bury their bows. One with and one without a bow spirit. How much slower is the recovery by the boat with bow sprit versus the one without? |
Many boats without bow sprits have pinched bows. This is no accident. The pinched bow is often to extend the bow forward, so the bowsprit is not needed. Boats that have bowsprits usually have fuller, more buoyant bows.
__________________ I am highly suspicious of the terms 'perfect' and 'best'. I favor the terms 'inadequate', 'adequate', and 'better', instead, with the first of these closest to being an absolute. |
With long keels, the Center of Lateral Resistence (CLR), not to be confused with the Center of Lateral Area (CLA), often ends up quite far forward. This is very likely to be the case with full length keels that are level and have no downward slope aft. Comercial sailing ships had to contend with draft as an issue, so were forced to have level long keels. You see long bowsprits on just about all of them.
__________________ -- John ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Check out my boat building blog: http://www.unlikelyboatbuilder.com/2009/09/boat.html ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
| Effects of sprit. Sharpii2. (and Jalmberg) Just for the purpose of discussion, let's isolate the effects of the bow sprit and assume identical bows. How much difference could one reasonably expect? |
![]() The difference would not be zero, of course, but I doubt you'd notice the difference. A better strategy is to heave to and avoid the scenario altogether! -- John
They have a damping effect on the pitching too. As the bowsprit enters the water it's travelling fast and throws up a lot of spray the pitch slows, stops and the bow recovers but slower than it entered so there is a greater slamming resistance and a slower recovery. The boom is stayed and it will not break off unless the stays break and they should be sized and attached accordingly. If you look to the working boats of sail and their design rules of thumb you'll get a good idea of robust bowsprit design since the loss would have been catastrophic. It's very common to ship green water as the sounding reduces and the waves get steeper and closer together .
| i do not want to have my forestay mounted to the bowsprit.... sail a blister, gennacker or whatover from it - yes - but the forestay i like to have securely mounted to the hull.... apart from that, i am with mike... |
| Bowsprits have their own stay. There is a forestay attached to the bowstem or close to it
| sprit rig cutter & weather helm | Oldlugger | Boat Design | 14 | 02-02-2009 09:40 AM |
| Extending bow sprit? | Pylasteki | Sailboats | 11 | 04-25-2008 04:43 PM |
| Big Bow Sprit Water Tightness - Methods | Scott Carter | Wooden Boat Building and Restoration | 4 | 10-29-2006 04:13 PM |
| Is there law on high seas? | tarrysailor | Open Discussion: All Things Boats & Boating | 17 | 09-18-2005 02:43 PM |
| olson 30 sprit | antoine1 | Boat Design | 1 | 10-04-2004 07:42 PM |
