Old 05-20-2003, 10:24 AM
Boat Design for school
ok im desiging a sail boat (which we will race) and i need help. what kind of hull would be the best to use? the boat dimension 3'3/4 width 12' long high doesnt matter thanks for the help in advance
Old 05-21-2003, 03:04 AM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
Were going to need some more info. I presume that this is a manned craft, and not a remote controlled model. Are you allowed a weighted keel, do you have any plans for the rig? (Una, or sloop rig would probably be best). In short, I don't know of any stock designs, and if the rules are virtually unlimited (length, beam and minimum weight) then the best course of action is probably to design your own. I would also suggest that you register on this forum, then you'll be able to post more easily.
So, in short, feel free to bounce ideas off us, but could you post a set of rules?
Glad to help,
Tim B.
Old 05-31-2003, 09:10 PM
Rep: 1493 Posts: 7,447
Are you familiar with the Penguin class? They are about the same dimensions.
Old 06-01-2003, 06:45 AM
http://home.dmv.com/~jenkins/plan.html
that may be a good place to start. I would also consider something of a hybrid design, between say, a laser style boat, and something slightly narrower, so you end up with a good hull at the right size. This looks like one of those projects that you'll just have to play around with.
Good Luck,
Tim B
new boat design 3d-design Boat Design 2 11-10-2005 08:15 AM
2005 nitro bay boat is this a design flaw? texas nitro Powerboats 24 06-06-2005 01:41 PM
Boat Design Proj designfreak Boat Design 31 04-15-2005 02:20 AM
I'm looking for first step into boat design ale2006 Boat Design 4 04-13-2005 08:11 AM
Folding Boat Design Archive Boat Design 0 06-12-2001 03:18 AM
