Old 09-08-2009, 05:12 PM
Slainte Slainte is offline
Block source?
Can anyone recommend a source for good, reliable wooden blocks? I'll be using 3/8" and 1/2" line. Thanks in advance.
Old 09-09-2009, 03:47 AM
Rep: 2891 Posts: 8,795
All wood or composite (wood and metal)? In both cases these are fairly easy to make yourself, if desired.
Old 09-09-2009, 04:13 AM
alan white's Avatar
Rep: 1168 Posts: 3,269
http://www.tsrigging.co.uk/traditional_blocks.asp
Old 09-09-2009, 05:16 PM
Member
Rep: -33 Posts: 951
Why wood? I can build a single aluminium block in 20 minutes, with hand tools, that is far stronger and more rleiable than most commercially built blocks.
Brent
Old 09-09-2009, 11:03 PM
I can too Brent, but does it look as nice as a set of freshly oiled teak blocks, dangling from strops on a dainty old gaffer?
Old 09-09-2009, 11:35 PM
alan white's Avatar
I've got teak blocks with medallions over the axles but those babies are not easy to find. For the classic look, solid broze is much easier to soure. Bristol Bronze carries those. Those old teak blocks are very well constructed. Never a problem at all, though they weigh a ton.
Old 09-10-2009, 02:49 PM
Member
Rep: -33 Posts: 951
While taking longer, it's not all that difficult to build those either, possibly less work than hunting them down.
Brent
Big block or Small block? Verytricky Inboards 15 10-10-2007 01:04 PM
Block Strength Cleetus Sailboats 2 09-20-2007 01:09 AM
Block coeficient songson Multihulls 1 08-09-2007 08:29 AM
Fix this block brokensearay Sterndrives 5 12-13-2006 10:16 AM
cracked block shelbygone Gas Engines 3 10-11-2006 08:57 PM
