Old 10-28-2009, 01:00 PM
ziola ziola is offline
Rep: 10 Posts: 2
Bilge taking on water
I've had my sailboat for a couple months now and the bilge has stayed dry the whole time. Yesterday it was starting to overflow so we pumped it out and this morning it's already about 3/4 full already. What problems could be causing it to build so fast? I'm thinking maybe it's from my sink? Any help is appreciated.
Old 10-28-2009, 01:07 PM
Rep: 494 Posts: 3,842
Any perforation can leak. The usual suspects are through-hull fittings, hoses, shaft stuffing box(on inboards) and keel bolts.
Old 10-28-2009, 02:05 PM
apex1's Avatar
apex1 apex1 is offline
Steamer
Rep: 592 Posts: 2,800
That request could´nt be broader formulated.
What about watching the area for a while, to see or hear where the water comes from?
Fortior est qui se quam qui fortissima vincit Moenia.
Old 10-28-2009, 02:23 PM
bistros's Avatar
bistros bistros is offline
Rep: 146 Posts: 368
Is your wife unhappy when sailing?
Old 10-28-2009, 05:59 PM
Rep: 10 Posts: 2
thanks for the ideas. going to keep my eye on it to try and figure where its coming from. I'm new to sailing so your help is appreciated
Bistros~ no unhappy wife, I am a woman
Old 10-28-2009, 06:55 PM
alan white's Avatar
Rep: 590 Posts: 2,640
Ziola, I think you need to describe the type of material the hull is made from. Fiberglass? Wood? It's easier to diagnose a problem like yours knowing as much as possible about the construction.
If the boat is fiberglass, look to through-hull fittings first. Shut them all and see if the leaking stops. Typically, there is one for engine water intake, one for toilet intake, one for toilet discharge, possibly for sinks as well, one for a depth transducer, and one for a knot meter, and that covers the usual holes. They can also leak from the crack between the through hull fitting and the hull itself, which will require hauling the boat.
While some hull penetrations have no valve to shut, all the in or out water pipes should.
Once all the valves are shut, pump the bilge and see if it still leaks. If not, open each valve one by one with enough time between valve openings to observe whether water is entering.
If the boat is wood and the above doesn't work to discover the problem, you should haul the boat ASAP and see where water pours OUT. This won't necessarily pinpoint the leak, but it will probably help to localize it.
My guess is you have an old hose leaking near the through hull fitting. It's not safe to fool with the hose without a shut-off valve unless you have experience as it will pour water while you swap hoses (a tapered plug should be at the ready). Sometimes valves are not even installed, believe it or not.
If it is a cracked hose leaking and there is a shut-off valve connected to the through hull, just replace the hose.
S O S ..... we're taking on water ... HighTide Open Discussion 24 04-12-2007 12:53 PM
Frozen water in bilge.. Adrian2 Boat Design 4 03-11-2007 11:59 AM
water in bilge of old boat llwjrw03 Fiberglass and Composite Boat Building 0 12-27-2005 08:20 AM
Oily Bilge Water Removal LKurelja Open Discussion 10 08-10-2005 09:32 AM
Water in bilge liloldham Powerboats 8 07-23-2004 09:37 AM
