Old 10-18-2005, 09:55 AM
greg simpson's Avatar
greg simpson greg simpson is offline
all steamed up
Rep: 10 Posts: 21
As you have just mentioned that you have a condenser,why not modify your feedwater tank: either make it larger/move it closer to balanced centre of boat/lower in the bilge?
Also,i'm not familiar with weston farmer hull designs,is yours counter sterned or transome?
does it have 'steadies' (i dont know their proper name) under the water line ie.4''/5'' x 1'' x 6'/7' peices of timber on the hull to act as extra rolling resistance without offering any real resistance to water flow past the keel?
Old 10-30-2005, 05:26 PM
roxanne parola roxanne parola is offline
Rep: 10 Posts: 5
Sorry mate, been gone for a few days, no can't lower fuel or water tanks since there are only a few inches below the floor in the bilge area. Weston Farmer was an naval designer of big stuff who liked steam boats, it is a counter stern style with a "cozy" at the stern and a proper Windermere tea kettle (we use it for hot rum, yum. Steadies?, never heard of such, any idea how effective they may be? Thanks RP
Old 11-01-2005, 10:50 AM
all steamed up
Rep: 10 Posts: 21
i dont know their proper name,i wish i did,but they run linear with the hull and are simply planks fixed onto the hull,making more surface area to resist rolling,but offer little more resistance in running,does that make it a bit clearer?
does anyone know what i mean that could tell us the proper name of these parts and if they would be effective in their role on roxanne's boat?
greg
Old 11-01-2005, 04:30 PM
cyclops cyclops is offline
Rep: 33 Posts: 1,059
Secondary or auxiliary keels.
Old 11-05-2005, 11:37 AM
Rep: 10 Posts: 5
greg, since you are interested in steam things check out; stanleysteamers.com. A site by a John Woodson, you can link over from there to "steamboats". Check out what's going on this side of the pond. Cheers RP
Old 11-11-2005, 06:56 AM
all steamed up
Rep: 10 Posts: 21
not to say cyclops is wrong,but if you search 'terminology' in the search engine and look at a post by kach21 it gives a picture of what i meant.
whether the name 'running strake' is correct or not i dont know,i thought that was a strake running allong the hull above the waterline to protect when berthing/moored etc.
hey ho,worth a gander anyway.
ps i'll look at the 'sites you list,thanks.
Old 03-10-2006, 10:35 PM
fredrosse's Avatar
fredrosse fredrosse is offline
USACE Steam
Rep: 29 Posts: 55
I converted an O'Day sailboat to electric, and cut out the centerboard well to make room for the prop shaft. This left me with a very round hull section, and no keel. I bolted two bilge keels, each about 14 inches off the boat centerline, and this works very well. I used 1/8 x 2 x 2 Aluminum angles, 6 ft long each.
Twin keel research MikeJohns Boat Design 125 06-16-2009 10:44 PM
Canting Keels In Production Yachts D'ARTOIS Sailboats 169 02-17-2006 05:06 PM
LONG Bilge Keels FAST FRED Boat Design 14 10-25-2005 01:36 AM
toe in??? capt'n ron Boat Design 10 08-03-2005 02:44 PM
Bilge Depth cklanac Sailboats 10 06-28-2004 04:32 PM
