Old 06-07-2007, 10:35 AM
Omeron Omeron is offline
Rep: 31 Posts: 163
Bending wood over steel frames..?
These are the pictures from 'spirit yachts' web site.
Always wondered,how such two very different materials, with different
mechanical properties, can be married to form a load bearing structure.
This is not even a static structure, like a building,where you would expect the steel to carry the load, and wood to cover it up.
Here, i guess, the wood frames are load bearing, and the steel is providing additional strength and stiffness near the keel area.
So both of them are required to play their part.
What happens when the entire hull flexes,when temparatures go high and low, when humidity changes,or after a million time of cyclic loads.
As an engineer, i was thought, not to mix and blend two different materials,
as eventually, they would work themselves out and start to behave independently of each other with drastic results.
Well, may be, that was a long time ago, perhaps materials now go through
marriage counseling, before they are used!
Bending wood over steel frames..?-spirit_100_build_2m.jpg  Bending wood over steel frames..?-spirit_100_build_3m.jpg
Old 06-07-2007, 01:51 PM
nero nero is offline
Rep: 112 Posts: 624
http://www.ledonduvent.com/
This ship was built in Germany in 1940. It is steel/iron frames, wood keel, and wood planking bolted on. She is quite tight and has no leaks in the hull.
When she is hauled out for bottom work and then put back in all the planking seams move a bit. Just enough to crack the paint.
Old 06-07-2007, 02:43 PM
jehardiman jehardiman is online now
Rep: 1623 Posts: 1,483
You need to get a good book on how ship structures work and the loads that they are subjected to. You really need to understand the different nature and requirements of a free floating body subjected to primary (girder), secondary (frame), and teriary (shell) loads. A civil or mechanical engineering background poorly prepares you for analyizing ship structures, (I know, I've had to educate a few in my time). In the picture you show, the wood is to hold the planking and the steel is to hold the shape. The hull is supported as flexible open shell with sectional properties maintained by the more ridgid frames. They are using the materials correctly.
Old 06-09-2007, 07:56 AM
la cage la cage is offline
Rep: 10 Posts: 17
The moisture content of the wood, in the contact area between the steel and the wood will always create a problem wheather internally or externally. The steel mesh that I use with a variety of materials has not been a problem, because the steel is incased in a closed cell foam before fibreglassing.
www.bourneboats.com.au
Alternative method of boat building!!!!
Old 06-11-2007, 06:10 AM
Rep: 1623 Posts: 2,344
The frames are stainless steel. I hope they have carefully considered their SN curves.
Composite ships, Iron frames with wooden planking were used a lot before ships moved to metal plating.
Originally Posted by la cage View Post
The moisture content of the wood, in the contact area between the steel and the wood will always create a problem wheather internally or externally. ...... .................
Cage
Although modern bedding sealants have significantly diminished this problem and in this application they would stop all problems WRT trapped moisture.
By the way your construction technique is certainly novel and a discussion of it is worthy of a new thread.
Mike Johns.
Old 06-12-2007, 05:43 AM
Rep: 10 Posts: 17
New Thread
As recommended by Mike Johns please find new thread for discussion of the Bourne Method of Boat Building at,
http://www.boatdesign.net/forums/sho...275#post146275
I look forward to hearing what you think of this method of construction.
Old 06-16-2007, 12:11 AM
Pierre R Pierre R is offline
Rep: 458 Posts: 461
surprisingly steel and many hardwoods have vary similar expansion properties. The wood also has some give and will accomodate in all the right places. I see no problems with this type of construction.
I would have a concern with the quality of stainless used as the stainless would be subject to crevice crack corrosion between the wood and the stainless in the presence of standing water.
Old 06-16-2007, 11:10 AM
Paul Scott Paul Scott is offline
Rep: 84 Posts: 272
fwiw, Steve Rander's 'Rage' was done with a steel frame, c.o.v.e system- e glass, cedar, eglass, klegecell, e glass, cedar, e glass. West System, e glass and wood used unidirectionally. Rage has been raced a lot for a decade or so- it's so light and fast that it gets airborne off of waves (I asked Steve what it was like when he landed, and he said it was like a garbage truck landing on a house). They put Rage on a sand bar at 11K, got off and continued racing.
Google Schooner Creek Boat Works, and you'll find info on her. She was banned from the transPac for years.
Paul
Old 06-18-2007, 04:01 AM
Rep: 31 Posts: 163
Pierre R, wouldnt it make sense to coat steel with some suitable
material, and make it waterproof before bending the wood over it?
Since it is not going to be submerged in water, any decent paint,
epoxy etc, could cope with precipitation, humidity etc.
But i guess the bore holes would still be problem areas.
Old 06-22-2007, 03:50 PM
MMNet SEA MMNet SEA is offline
Rep: 17 Posts: 66
Looking at the pictures - it appears that the metal frames are only there to provide the correct bend to the laminated wood frame during the lamination process. The metal frame patterns remain in the builders yard ????
Old 06-22-2007, 04:28 PM
No, those are ring frames, not moulds, otherwise there wouldn't be camber in the "deck" and all the expensive lightening cutouts.
Old 06-22-2007, 04:42 PM
Rep: 17 Posts: 66
unfortunately the picture's scale gave me the impression that the distance between the top and bottom of the ring frames would be inadequate for internal cabins etc. I guess I was misled by the size of one of the clamps.
Thanks
Old 06-25-2007, 02:55 AM
Rep: 31 Posts: 163
This is an impressive boat by 'Spirit' Yacht.
If you browse their site, you will see the entire boat, and the permanantly
installed ring frames.
Old 06-25-2007, 03:23 AM
Rep: 17 Posts: 66
Omeron can you give the full URL? - the one that shows the ring frames.
I could not find the specific one.
Old 06-25-2007, 06:53 AM
Rep: 31 Posts: 163
www.spirityachts.com
Home page starts with the pictures of this boat. 'spirit 100'
Laminating frames for small boat...What wood? Northshore Wooden Boat Building and Restoration 15 09-03-2007 07:47 AM
Steel frames & ply cladding anyone sandpiper Boat Design 42 08-16-2006 12:12 PM
Wood Ring Frames photjoe Boat Design 1 06-28-2006 10:47 AM
Wood on Aluminum Frames aleks Wooden Boat Building and Restoration 13 10-30-2005 07:34 PM
Bending Stainless Steel mojounwin Metal Boat Building 4 10-25-2005 10:25 PM
