Old 04-18-2007, 12:33 PM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 43 Posts: 624
basic physics and Di
I was trying to understand how induced drag relates to speed with a constant lift, by assuming that at twice the speed each volume of water is affected by the same downward force at half the time, so it should be accelerated to half the downward speed.
Can you tell whether I got the stuff right so far?
basic physics and Di-seglebruksanvisning.jpg  basic physics and Di-speedlift.jpg
Old 04-18-2007, 03:39 PM
Rep: 1623 Posts: 1,483
I think you are making this much too complicated, i.e. "ghost lift"?...See Marchaj, Aero-Hydrodynamics of Sailing, part 2D or Hoerner; Fluid Dynamic Drag, Chapt 7.
But as to downwash being half because the time is halfed?...yeah, but that is not a good way to look at it at all. The downwash is haved and therefor the Di is 1/4 because the angle of incidence is quartered to reduce the lift by the speed squared.
L =m *2w
m = rho*A*Vo
2w=Vo*2alphai
therefor
rho *A* Vo^2*2alphao = rho * A*(2*Vo)^2 * 2alpha2
2alphao=4*2alpha2
then
2w(o) = 4*Vo*2alpha2
2w(2) = 2*Vo*2alpha2
and
Di(Vo) = L *(4*2alpha2)/2 = 4*L*alpha2
Di(2) = L*alpha2
This falls apart BTW if viscous effects are considered.
Old 04-18-2007, 06:29 PM
Previous Member
Rep: 0 Posts: 0
To understand "Induced Drag" you need to consider the foil in 3D. Induced drag is related to longitudinal circulation over the ends of the foils so is a function of foil aspect ratio, plan form and lift coefficient. This explains it:
http://selair.selkirk.bc.ca/aerodyna...rag/Page6.html
This site is helpful in getting the lift for a foil:
http://www.lerc.nasa.gov/WWW/K-12/airplane/foil4.html
Unfortunately it does not provide drag.
I have a series of polar curves for high L/D foils to get accurate coefficients of lift and drag. These coefficients are highly dependent on Reynolds number in my area of interest. You can produce some useful foil data using this site for a reasonable range of foils:
http://www.mh-aerotools.de/airfoils/javafoil.htm
(It can take a while to load)
Old 04-20-2007, 02:00 AM
tspeer tspeer is offline
Rep: 1313 Posts: 1,523
That's correct. Lift = density * velocity * average circulation * span, and the induced velocity is proportional to the circulation, so twice the speed means half the circulation.
Since the induced angle of attack is proportional to circulation / velocity, this means the induced drag at constant lift varies as 1/velocity^2.
Tom Speer
Another Physics Brain Teaser DGreenwood Open Discussion: All Things Boats & Boating 205 06-14-2007 08:54 AM
A Physics Brain Teaser Man Overboard Open Discussion: All Things Boats & Boating 42 01-27-2007 02:18 AM
Basic Question mav067 Electrical Systems 4 08-03-2006 05:52 PM
Boat Design using toothpicks for Physics Project tpru2000 Boat Design 4 05-16-2005 10:46 AM
Basic needs.... Sean Herron Boat Design 1 09-09-2004 11:41 PM
