Old 06-22-2011, 03:54 PM
mark hannon mark hannon is offline
Mark Hannon
Rep: 20 Posts: 2
Bamboo as mast and spars
Anyone know of a source for bamboo to be used for spars and masts? Up to 18 ft and 3 inch diameter, ect. Thanks, Mark.
Old 06-22-2011, 04:17 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,603
Hope this can lead to some help: http://canoesailingmagazine.com/inde...and-Spars.html
yes, it is a revolution
Old 06-22-2011, 04:40 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,357
Wooden mast building
Hoyt
Old 06-22-2011, 06:56 PM
CutOnce CutOnce is offline
Rep: 205 Posts: 470
I've used Tonkin construction grade bamboo as spars for my son's boat. It was a low cost design, with a projected life span of three to four years. The spars have held up perfectly. Checking and splitting can and does happen due to humidity changes.
CutOnce
Old 06-23-2011, 04:41 AM
Rep: 3125 Posts: 9,403
Bamboo would seem a terrible choice for spars on all but the smallest boats. Even on these you're paying huge weight penalty for the convenience of using bamboo.
Old 06-23-2011, 01:22 PM
Rep: 205 Posts: 470
Bamboo as a raw material is quite interesting and strong if processed carefully. The long, well dried fibers are incredibly strong and light in both tension and compression.
During the build and rigging of my son's little boat, I had to purchase more bamboo than was needed (about 150% more) just to make up the minimum shipment ($35 I think?) required to deal with the vendor. Eric McNicholl, designer of my son's boat was building an excursion/challenge sail boat for a client at the time and he was interested in seeing what could be done with bamboo as a composite component material. Part of his interest was due to bamboo being a sustainable and cheap material - the other was the general satisfaction the bamboo delivered in the children's boat application.
The client building the excursion/challenge sailboat (I think around 27', cat ketch rigged, open) was willing to try the bamboo composite mast and was so happy with it they built a second. The bamboo was ripped into fibres, assembled on a mandrill and then carbon epoxy wrapped (I could be wrong on details, so Eric should be contacted for accuracy). The resulting spars were light, incredibly strong and made both designer and client happy. They are well into their second season of heavy use with no problems as of my last contact.
Although no material is perfect, it is kind of nice to find one that can regrow in a year or two. Given the pricing, bamboo as a raw material is dirt cheap.
I'm not disputing PAR's position that raw, unprocessed bamboo would have many issues if scaled beyond a tiny, cheap and limited lifespan boat, but looking further than just using dried bamboo stalks was an interesting experience with a happy client in this case. I know Eric said they learned a lot about working with bamboo during the process, as it was completely new and foreign material.
Bill
Old 06-24-2011, 12:28 AM
Using bamboo as Bill describes it seems reasonable, though I think there are much more cost effective choices then cabrom and bamboo fibers. How about Spectra strands and carbon?
An 18' by 3" diameter bamboo pole will be quite heavy and fragile.
Old 06-24-2011, 01:40 PM
Rep: 205 Posts: 470
You'd be surprised how light bamboo is when dried. The Tonkin contruction grade bamboo I purchased is used in many parts of the world as construction scaffolding and (from memory, so could be off) an 18'x3" diameter span would weight around 6-9 pounds dry. Found a distributor here in Canada who brings over containers of bamboo and sells it to garden centers and landscapers as fencing material. Given Eric reduced the material to long 1/8" fibers and got rid of the section barriers, it was pretty light as a core filler.
Spectra strands certainly would have great strength in tension, but effectively nothing in compression. Would be lighter though, but nowhere as cheap.
When Eric first said he was going to try this, I thought it was a Kyoto-inspired bong hit thought, but the resulting spar was amazing.
CutOnce
Old 07-12-2011, 12:36 PM
DESQ DESQ is offline
Rep: 10 Posts: 3
There's an ouftit on Lakewood NJ with great variety in bamboo species available; they may ship:
http://www.bambooandrattan.com/
I agree that bamboo not terribly suitable for a mast. That said I love it for sprit and boom on my Opti rig and also for boom and yard on my ACA lateen rig.
Use dowels glued into the ends prior to drilling for outhauls, yard/boom connections, and the like. You can also lash/whip bamboo along its circumference to keep from splitting or binding together where you have splitting. It's amazing stuff. I also split some out with a froe and, after working the staves with thickness planer and crooked knife, use the bamboo for transverse ribs in a skin over frame kayak. They are light and robust. An Umiak with bamboo ribs would be a neat project.
Bamboo Detailman Materials 33 07-24-2011 04:08 PM
Home-made small fiberglass mast/spars? hospadar Fiberglass and Composite Boat Building 15 05-17-2011 03:50 PM
Bamboo boats DavidMJordan Boat Design 3 08-21-2010 11:53 AM
bamboo planks adriano Materials 46 08-27-2009 06:49 PM
Building bamboo kayak (bamboo and recycled wood) from Brazil-Brasilia-DF cadaisdf Boat Design 0 03-11-2009 07:14 PM
