Old 11-09-2007, 01:02 PM
b.amateur b.amateur is offline
Rep: 10 Posts: 11
Baltic & other early sandwich designs
Hello everybody,
finally joined after reading in this forum for a few months.
I have a couple of questions on the 1970s/early 80s Baltic models.
I am looking for an absolutely seaworthy boat around 40 feet that sleeps at least 6 people but is still safely manageable by a couple of which one is a non-sailor.
A Balsa sandwich construction is favorized by me, not only for the weight, but also because of better fatigue resistance - my budget only allows a boat aged 25+ years.
Here comes the first problem: I only know of Baltic building cruising boats from sandwich construction in that time - would like to broaden my range of choice - can you tell me some other boatyards that did the same in comparable quality (donīt want to start digging out a rotten balsa core...)? Wasa could be an example...?
Has anybody heard of a 1970s Baltic with serious water damage/rot in the deck...or god forbid even the hull?
Another question: What do you think of the Baltic C&C constructions with respect to being handled shorthanded? The 37 should be no problem, but I also have a 42 in mind. You know if it was derived from the 1975 Tina-I-Punkt built for the German Admiralīs Cup team?
And finally: Iīve read in this forum that there was a version of the Doug Peterson Baltic 42 built in South Africa (under the name Magnum). Have other Baltic models been built down there as well?
Thanks a lot for giving your opinions,
a bloody amateur
Old 11-12-2007, 05:52 PM
Gilbert Gilbert is offline
Rep: 28 Posts: 511
I think you may find that older boats with balsa core are more likely to have osmosis problems than newer ones, meaning the core could be wet and have potential delamination issues. So please be careful about that aspect of any vessel you are considering.
late 60's, early 70's slickcraft 160 donp Powerboats 14 12-08-2008 01:38 PM
Keelchange baltic 42 steffen Sailboats 5 07-19-2006 01:40 PM
Sandwich Superstructure fencer Fiberglass and Composite Boat Building 5 07-01-2005 10:13 AM
Baltic Trader connor regan Boat Design 0 06-07-2004 09:47 PM
baltic 35 verasail Sailboats 2 06-02-2004 04:52 PM
