View Poll Results: What Ballast would YOU prefer?
Standard Fixed Keel 16 51.61%
Moveable Water Ballast 4 12.90%
Canting Keel 11 35.48%
Voters: 31. You may not vote on this poll
  #46
Old 04-30-2007, 07:18 PM
robt.c.warford robt.c.warford is offline
Rep: 10 Posts: 6
Three circumnavigations plus and I like my ballast glued on SOLID.
  #47
Old 05-06-2007, 12:56 PM
xarax xarax is offline
Rep: 51 Posts: 277
Canting mast on a fixed keel hull.
Righting force is created this way,too.
(Does it count for a fixed or a canting (related to the mast) keel?
  #48
Old 05-06-2007, 01:43 PM
DanishBagger's Avatar
DanishBagger DanishBagger is offline
Never Again
Rep: 523 Posts: 1,543
A weighted swing keel (not a canting one, but the old-fashioned one).
But then again, I don't mind not coming first – at least I will be safe, sound and in a good mood.
  #49
Old 07-11-2011, 06:41 PM
sharpii2 sharpii2 is offline
Rep: 419 Posts: 854
Originally Posted by gbr43926 View Post
Hi all,
When considering a modern Medium sized racing yacht, for example a J 109 (35ft) what type of ballast would YOU prefer?
Basing your opinon on;
Righting force created,
Affordability,
Useability,
Reliability,
+ anything else which would sway your decision.
Options are;
A) Standard fixed keel
B) Movable water ballast
C) Canting Keel - please state if engine/non engine hydraulic, pulleys? etc
Thanks!
INMHO, any sailboat that needs an engine constantly running is a motor sailor and should be classified as one.
If I'm going to allow someone an engine to cant their heavy ballast, I should also have to allow someone use the same amount of engine and fuel fitted to a propeller.
Man the manual hydraulic pumps, matey. Pump like yer lives depend on it! What is worse?
Losing or dying?
If you pick the second choice, what kind of racer are you? Ahrr!
Seriously.
This question is too open ended to mean much.
There is a whole galaxy of options open to racing.
I'm aware of at least three different kinds:
1.) One design, (very highly restricted)
2.) Class design, (a little less restricted) (includes rating systems in some cases) and
3.) Open (very mildly restricted. Often just length, with a few safety requirements, and multihull or a monohull specific)
The first part of your question should have specified which of these three types of racing we are talking about.
Also, are we talking about what we would choose if we were setting up a new class or one design?
Or are we talking about just an individual boat?
In the second case, if I were Bill Gates rich, or even Kieth Richards rich, I would want to have the fastest thing afloat, limited maybe by just length.
If it breaks, I can always throw it away and get a new (and even faster) one.
Its one thing to win after a committee considers your rating. It's quite another to win by being the first across the line. I would much prefer the rest of the fleet looking at my transom.
In this case, I would definitely pick a canting ballast with an engine to cant it, if I could get away with it.
It's a very hard thing to beat and is probably safer than a deep, fixed bulb keel. It seems all the bulb keels I hear of getting into trouble have been the fixed type.
Not that it is inherently less safe, but because it offers idiot designers and builders engineering options that should best be ignored.
Besides, about three decades of open design (mono), single handed, long distance ocean racing has all but proven the canting ballast concept is king.
In racing, the equipment gets to reside in the best part of the boat. It's what makes the boat go fast. The crew are just cargo. Stick 'em anywhere they will fit.
As long as they are out of the way.
Now that's if we are talking monohull, (also not specified in your question).
If we are talking multi, gimme foils for my leeward floats.
Why drag all that hull through the water if I don't have to.
Just let me get the relatives I least like out of my will, before we depart.
...I never learned a thing from an argument I won...
Loran or GPS? What's your preference? jedclampit OnBoard Electronics & Controls 20 06-15-2007 03:04 PM
ABS Offshore Racing Yacht, definition of Section Modulus? JesperW Sailboats 13 07-21-2006 06:16 AM
Water Ballast & Keel Ballast jag459 Sailboats 4 09-08-2005 02:39 PM
Water Ballast vs Keel Ballast jag459 Boat Design 13 09-08-2005 08:01 AM
Water Ballast vs. ??????? LP Sailboats 5 08-04-2005 12:28 PM
