  #31
Old 02-04-2011, 10:19 AM
SuperPiper SuperPiper is offline
Men With Little Boats . .
Rep: 58 Posts: 277
I had a loaner last season. I had backed it with a 3/16" piece of Lexan. It was cut to fit the full width inside the cover and was about 4" high. It was not bonded in place. I didn't know if that was adequate or inadequate. Hence the question in Post #1.
From this exercise, I now realize that the Lexan did spread the load to the structure. But, it did not add any strength to the structure. If it (or something of similar dimensions) had been epoxied to the keel trunk cover, then the cover itself would have been stronger for the same weight.
Interesting stuff.
Have a good weekend bntii!
  #32
Old 02-04-2011, 11:13 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
All that and you used phillips heads?
I would have run more thread through the nuts (i.e. longer bolts).
No washers on the front are necessary but certainly would have done no harm.
When/if this set-up fails, it will be at the top of the backing plate as there is no feathering, this creates a stress point (line).
Overall, nice job, I don't think you'll be disappointed.
Must be a very short stove or are you planning on recessing the floor?
-Tom
  #33
Old 02-04-2011, 01:23 PM
bntii's Avatar
bntii bntii is online now
Rep: 1073 Posts: 704
You too Piper- the boat is lookin good.
  #34
Old 02-04-2011, 02:54 PM
mark775
I guess I should have looked at what stove was being mounted. That was the stove this thread was devoted to?! - Double-sided tape/chewing gum/a radar detector suction cup. Good grief, what a waste of time.
  #35
Old 02-04-2011, 07:25 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
"Good grief, what a waste of time."
...yep, that just about sums up the whole thead.....ya got ta larf....
  #36
Old 02-06-2011, 06:00 PM
Rep: 58 Posts: 277
-Tom
Tom, what is the comment about phillips heads?
How many threads should have been through the nuts? Are you OK with nylocks?
  #37
Old 02-06-2011, 07:25 PM
Mariner
It's fine SP. I love nylocks. Phillips heads suck, but that's just my personal opinion. I use robertson, a Canadian invention not commonly available down your way. I usually leave three threads showing through the nuts.
It's all good big guy, you did a nice job, have a good sleep.
-Tom
  #38
Old 02-13-2011, 04:49 PM
Rep: 58 Posts: 277
Not The First
I was reading the ABS 1994 Guide For Building And Classing Offshore Racing Yachts. There is probably a newer version in the public domain. I didn't look. I kind of stumbled upon the 1994 version. That is the era when NAs like Bruce Farr were on the International Technical Committee for the Offshore Racing Council.
In Section 7 - Plating: " . . . the thickness of the bottom shell . . . is not to be less than the diameter of the keel bolts."
There it is. Thickness = bolt diameter. The rule is obviously good in the 1" bolt range.
The document also included the attached Table 4.3 - Basic Laminate Properties. It listed Shear Strength as being between 9,000 and 11,000 psi. That is about 1/3 what I quoted back in Post #10. The lower shear strength actually validates the 'fender washer' part of the rule. I had arbitrarily inflated the washer diameter to 'fender'. Using the lower shear strength actually computes the diameter of a fender washer.
I thought the rule had been developed here on BoatDesign.net. Someday I'll recognize that the planet is populated with folks smarter than me.
  #39
Old 02-23-2011, 05:54 AM
Rep: 58 Posts: 277
Finishing Washers
I'm still working on some repairs and modifications to the keel box cover. Here is a straight forward question.
When/why do I use FINISHING washers? For cosmetics? To jump the holding pressure to the outside diameter of the hardware? Are there advantages/disadvantages vs flat washers?
Thanks for the help.
  #40
Old 02-24-2011, 01:06 AM
Mariner
Spreading out the load, avoiding pull through, etc.
Why?
-Tom
  #41
Old 02-24-2011, 04:09 AM
Rep: 58 Posts: 277
There are a dozen and a half #6 screws holding the keel box cover to the liner of the cabin sole. The holes in the cover are mostly busted and split. I'm in the process of removing the gelcoat and applying some glass along the bottom of the cover to re-enforce it.
When I screw the cover to the liner, should I use panhead screws with flat washers? Or, should I use flathead screws with finishing washers? I'm not sure of the differences.
  #42
Old 02-24-2011, 10:27 AM
Mariner
Without a picture, I would say pan-heads with flat washers. Providing of course, you do your fiberglas repairs. Why did it fail in the first place I wonder...
-Tom
  #43
Old 02-24-2011, 10:51 AM
rxcomposite's Avatar
rxcomposite rxcomposite is online now
Rep: 746 Posts: 785
Superpiper,
You are mixing things up. The rule of thumb was not developed here in the forum but rather by builders and designer who had years of experience building a boat. The thumb rule would most approximate the Class Rules.
Seaking of Class Rules, the bottom plating thickness is different from the keel thickness. The keel plating is the thickest part of the boat and sometimes designed to "bolt on" a keel, not a mere keel cover. The plating thickness is designed first then a bolt diameter is chosen, not the other way around. Without picking up my ABS guide book, I know the rules specifies minimum bolt spacing for different bolt diameter. So first thing first, design the thickness then choose a bolt diameter not to exceed (not equal to) the plating thickness, then determine bolt spacing.
When we talk about fender washers, we do not consider only shear strength but compressive strength as well. FRP is poor on compression and has a tendency to "creep" or relax under prolonged load. Some bolts are known to loosen up over a period of time due to creep.
As for the panhead and flathead, it is easy to see that the panhead is flat after the head while the flathead is countersunk and would dig in the laminate without the finishing washer.
  #44
Old 02-24-2011, 11:01 AM
Mariner
rx,
SuperP is talking about #6 screws...
-Tom
  #45
Old 02-24-2011, 01:05 PM
Rep: 670 Posts: 2,457
Originally Posted by rxcomposite View Post
Superpiper,
yes...well stated.
also for fasteners...countersunk vs pan head is a critical detail when mounting technical...highly loaded gear.....always consult the scantling, material rules when chosing between the two
Backing Boat Up Hill JUSTRITEBOAT Open Discussion: All Things Boats & Boating 3 11-09-2010 08:56 PM
teak rubrail backing William C. Wins Fiberglass and Composite Boat Building 3 05-18-2010 05:55 AM
bedding/backing through hulls pasty63 Diesel Engines 12 01-14-2009 05:02 AM
Headliner backing Gashmore Boat Design 5 02-19-2008 04:05 PM
Backing Rudder tips? fastfred Powerboats 3 06-27-2004 03:18 AM
