Old 07-25-2011, 10:43 PM
TJL TJL is offline
Rep: 10 Posts: 2
Asymmetric spinnaker design
A curiosity question - what is the difference between an asymmetric spinnaker designed for an offshore yacht compared to an asymmetric spinnaker from an 18 foot skiff?
Old 07-26-2011, 03:54 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
when you say offshore yacht do you mean a planing hull
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 07-26-2011, 08:09 AM
TJL TJL is offline
Rep: 10 Posts: 2
This poses a variation on the same question - what is the difference in design between an asymmetric for an offshore planing hull versus an offshore displacement hull?
Old 07-26-2011, 08:58 AM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,603
You might be better off asking a sailmaker. Generally, the faster the boat the flatter the spinnaker .On very fast boats the asy spin becomes a screecher-very flat and more jib like-and can be roller furled.
yes, it is a revolution
Old 07-26-2011, 05:32 PM
Stumble Stumble is offline
Rep: 604 Posts: 1,086
TJL,
Just to elaborate on what Doug said. The design of the sail itself doesn't really change much. What changes is the designed angle of the apparent wind to the sail while flying. An asymetrical made for sailing dead down wind will look pretty much the same regardless of the boat, it will have a large windward projection, and a deeper cut draft.
As the apparent wind angle moves forward (either due to boat speed, or sailing angle) the ideal sail will loose the windward projection, and the draft will start to flatten to look more like a jib. Typically the sails are given codes based upon their designed apparent wind angle, with a Code 0 being the most upwind, then a code 1a, code 2a, ect.
In addition the weight of the material tends to get heavier as the sail is designed more for upwind. Though code 0's are often very light, since they can replace a wind seeker in very light air.
Looking for info on Asymmetric hulled boat. bearflag Sailboats 8 07-08-2010 09:43 PM
Small asymmetric power cat rosbullterrier Boat Design 5 01-28-2010 06:10 PM
asymmetric spinnakers Daz925 Sailboats 4 03-21-2009 09:57 AM
Asymmetric hulls Trevlyns Multihulls 26 12-15-2006 03:36 PM
Carbon Spinnaker Poles RThompson Fiberglass and Composite Boat Building 10 06-30-2005 09:03 AM
