Old 01-10-2011, 01:47 PM
MastMonkey MastMonkey is offline
Rep: 43 Posts: 90
Appropriate Scale for Modeling
I am interested in true twin keel designs. It seems designs incorporating them have had mixed success based on my reading of the subject here. There have been some suggestions that they could offer some performance advantages due to the more effective lateral resistance a twin keel offers as well as the potential to shape the keels with asymmetrical profiles. If I wanted to pursue some research into effective twin keel arrangement, determining details such as the most effective camber, location fore and aft, appropriate corresponding hull type, which scale model would be give me results that could be applied to a life size hull?
Old 01-10-2011, 03:53 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Everything could be true about twin keels except that one. Twin keels will give less total lift and more total drag, when compared to a geometrically similar single keel of the same total surface, thus making it less efficient in generating lateral resistance.
Old 01-10-2011, 04:55 PM
Rep: 1493 Posts: 7,447
Twin keels have two advantages: One they draw less water, and two they keep a boat level at low tide. From the performance point of view, there are no advantages.
Old 01-10-2011, 06:34 PM
Rep: 43 Posts: 90
Maybe a more appropriate question then would be to determine how to preserve the advantages of the fixed keel (i.e. shoal draft) without sacrifices made to performance. If a twin keeled vessel could equal the performance of a single keeled vessel, without a loss of performance, it would be advantageous. Per the performance, my concern was not to best the single keel, but to overcome the limitations of twin keels. I am under the impression that a couple of unique aspects, mentioned in my original post, of the twin keel arrangement could help it do so. That one keel is always vertical has potential for improved later resistance over a heeled singled keel vessel was my belief. I would like to conduct research similar to what Patrick Bray did into twin keels:
http://www.brayyachtdesign.bc.ca/article_twinkeels.html
But I am uncertain at which scale results of a model test would be accurate and scalable. My interests is in determining the ideal twin keel arrangement through experimentation. The article mentions that there is not much data regarding hull form testing of vessels specifically designed to be twin keeled vessels and it implies that there may be a combination of hull form and keel arrangement that can match a single keel for performance.
Old 01-10-2011, 06:51 PM
Paul B Paul B is offline
Rep: 15 Posts: 1,770
Perhaps you should ask the staff at the towing tank facility you plan to use for your experiments?
Old 01-10-2011, 07:04 PM
BATAAN's Avatar
BATAAN BATAAN is offline
Rep: 1090 Posts: 1,502
3/4 inch to the foot is 1/16th full size and is easy to square, extract square roots from, and to cube. Speed in scale proportion is as to the prototype as the square root of the linear ratio. The linear ratio is 16. Sq root of 16 is 4 so the model will exhibit scale behavior at 1/4 the speed of the full size design.
As to displacement, scale varies by the cube of linear ratio, on 3/4" scale as 16x16x16=4,096, so if your model trimmed to waterline weighs one pound the real boat weighs 4,096 pounds. A Lincoln penny scales out at exactly 25 pounds scale weight at this scale.
I've taken the above from Weston Farmer, who gives a very detailed account of how to build scale flotational models from poster board centerline bulkhead and shaped bulkheads, 1/8" balsa planking and waterproofed with shellac and varnish, in his book "From my old Boat Shop". As he began NA practice in 1919 and worked until the late 70s he has some lessons for all who would know something about how powerboats go through water.
The man was a virtual preacher for using cheap models to prove a drawing board design before any timber was purchased and said it saved his ass numerous times in stupid mistakes.
Honest men make honest boats.
Old 01-10-2011, 07:10 PM
I think every notable test tank in the world will tell you that a 1/16 scale model is pretty useless as a test model.
Old 01-10-2011, 07:24 PM
BATAAN's Avatar
I've never done it myself but who said anything about a test tank? That costs money.
WF noted that a walking speed on 4 mph a scale speed of 16 mph is achieved.
All you need is calm water and knowing what you're looking for in the wake/speed behavior. The towing line must be low, a needle puts it below the w/l and in the extension of proper shaft angle. Use a fishing rod to tow.
Method works for boats 15 to 50 feet quite well for $10 materials and a few hours work.
At many Yachtsman's Dollars per hour, much more expensive model, technicians hovering, a test tank is real cool if you're designing an America's Cupper or TITANIC but for most plain boats this is enough.
Old 01-10-2011, 07:34 PM
Your Rube Goldberg method does not tell the original poster anything about what he wants to learn.
Old 01-10-2011, 07:39 PM
I think Bataan is answering the question of scale. 1/16 scale would give you a 2' model for a 32' boat which is adequate.
Old 01-10-2011, 07:45 PM
BATAAN's Avatar
It's certainly not my Rube Golberg method as I'm far too dumb to figure it out.
WF was a NA of 60 years experience and I merely quote him.
The poster asked for an appropriate scale to judge his design with.
Old 01-10-2011, 07:51 PM
Adequate? To determine what?
Old 01-10-2011, 07:52 PM
Your answer to his question is about as useful to him as simply writing different configurations on slips of paper and drawing them randomly from a hat.
Old 01-10-2011, 08:24 PM
thedutchtouch thedutchtouch is offline
Rep: 39 Posts: 90
i've heard of people using 1.5" to the 1'. same easy math as above, twice the size. 1 inch real = 1/8 inch scale model.
Old 01-10-2011, 08:26 PM
BATAAN's Avatar
Properly scale weighted 1/16 scale flotational model in a fishtank gives trim, stability and waterline info instantly and accurately. Towing same in flat calm and video taping the result gives more info on wake making and steering characteristics. This is how mechanics did it in the past and WF's 70 foot aluminum motoryachts are a testament to his using the technique, in support of his traditional design skills. Not every vessel design needs the ultimate NASA engineering approach to get a successful result. Some designers of the past were incredibly competent and I try to learn from them.
1/10 Scale frigate... volkswagen50 Wooden Boat Building and Restoration 19 08-29-2011 05:36 AM
Scale chandler Boat Design 27 03-26-2009 06:19 PM
Modeling capaworks Fiberglass and Composite Boat Building 1 09-30-2006 06:59 AM
Scale From 1:5 To 1:20 S Hondros Boat Design 3 01-29-2006 12:57 PM
Scale down? Zultar Sailboats 10 02-07-2004 03:46 PM
