Old 06-19-2008, 07:00 AM
Hostins Hostins is offline
Rep: 10 Posts: 21
Anhcor systems
Hello there, im having problem to find a seller for it,
a mechanical spring system for anchor.
Anyone got a clue ??
thanks!
Old 06-20-2008, 05:48 AM
Omeron Omeron is offline
Rep: 31 Posts: 163
Well, we may have a problem with this too.Perhaps you can give us a clue. What is a mechanical spring system for an anchor? Any pictures, drawings?
What boat? what anchor? etc...
Old 06-20-2008, 06:49 AM
Rep: 10 Posts: 21
i got a picture
finnaly
well,
the part that im looking for is the mechanical "arm" that lifts up the anchor from the inside of the Hull,
whats the propperly name of it ?
who can developīthat work?
thanks
pics attched
Old 06-20-2008, 07:26 AM
kenJ kenJ is offline
Rep: 56 Posts: 323
Bow Roller
Hard to tell from the picture but I think he is asking about a bow roller with a hinge that folds back into the anchor well.
Old 06-20-2008, 07:43 AM
Rep: 10 Posts: 21
i did marked what i wanna know
and the second picture is not the same part, but looks like
im tryin to find out who can develop that system
Old 06-20-2008, 09:27 AM
BillyDoc BillyDoc is offline
Rep: 266 Posts: 421
Hi Hostins,
So, if I'm understanding you, the mechanism you are interested in is a "bow roller and chain guide on an arm" that folds into a locker on the foredeck with the anchor attached when not in use. The hatches close, and you end up with a clean deck. To deploy the anchor you open the hatches, the "arm" rotates up and becomes the bow roller and chain guide --- and from there you are more or less conventional. Is that right?
I've never seen anything like this, but I can see the advantage of not tripping over the anchoring apparatus every time you visit the foredeck!
BillyDoc
Old 06-20-2008, 09:32 AM
Rep: 10 Posts: 21
YES! youre 10000% right
now i need to find someone to design it, any clues ?
Old 06-20-2008, 09:52 AM
Rep: 266 Posts: 421
Not right now, but I'll definitely give it some thought. I'm torn between "clean foredeck" (good!) and "complexity" (bad!) though. Let's hope someone else has seen these and can come up with a manufacturer, as I just hate re-inventing that damn wheel again, and again, and again . . .
Old 06-21-2008, 03:41 AM
Rep: 2891 Posts: 8,795
As a custom feature on a specific yacht, it could be effective, but retro fitting existing yachts would prove problematic for obvious reasons. Incorporating this feature into new designs would be possible though sanctioning and licensing manufactures (or designer's) to employ your device also seems wishful.
Do a patent search and see where you stand, then establish a reasonable business plan and go for it.
Old 06-21-2008, 09:41 AM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
is it fitting space to have the winch before the anchor and having a reversed anchor storage?
consequences also be than to have locker drainhoses deeper inside, intersting idea tho
Old 06-21-2008, 07:00 PM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
There has been a commercial alloy version of this for years from Italy.
Cariboni Giovanni
http://pdf.nauticexpo.com/pdf/caribo...-6578-_59.html
Old 06-21-2008, 08:35 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
Had a look at the designs at Cariboni
Is it my eyes, or does this drawing show a non symetric left hand wheel to make the whole thing lean to one side ?
Hope their engineering is better than their drawing -
Old 06-23-2008, 07:53 AM
Rep: 10 Posts: 21
i found also
http://www.pin-craft.it/prodotti_pin_craft_ing.php?C=23
under ANCHORS UPSETTING AUTOMATISM
Old 06-27-2008, 09:16 PM
ChicagoDrifter ChicagoDrifter is offline
Rep: 10 Posts: 9
High End Boats
I saw similar hydraulic designs in high end English manufactured cruisers.
Old 06-30-2008, 08:03 AM
Rep: 31 Posts: 163
Hostins, what is the boat in the picture? Is it a custom made boat or a production?
It is an interesting idea, and who ever manufactured that prototype i am sure can do it for somebody else.
It doesnt seem as though it is a complicated piece of equipment.
The very important pivot point is not visible in the picture. and also how it is squeezed in with the forestay attachment cannot be clearly seen.
Are you able to provide pictures of this detail?
I think it is also important to know how it works in practice. If you know the owner of the boat, it would be very interesting to get his comments.
From the picture i guess the whole lot would weigh around 20-25 Kg.
Lifting it and placing it on the bow without dropping would need some good arm muscles.
The chain stopper kind of bar in the photo seems to be in the way and looks like need to be removed before pivoting.
You also mentioned a spring in your thread. Is this lot spring loaded at the pivot to assist lifting?
Also, when in use, i guess there would be considerable load on the pivot point due to downward angle of the chain.
It would be interesting to findout more...
Thanks.
Electrical systems TerryKing Wiki 23 05-30-2010 11:30 PM
Demounting systems WildHare Boat Design 0 02-26-2006 04:49 PM
Steering systems diazklm Powerboats 2 11-11-2005 04:03 AM
Propulsion systems ??? tschienque Open Discussion: All Things Boats & Boating 1 09-08-2005 08:51 PM
HVAC Systems Tom Hoffmann Boatbuilding 0 11-10-2001 05:42 PM
