#91
| Foil ends In a mono and a tri you have one keel/daggerboard with only on end free against the water. On a cat you hav two end surface wich makes the daggerboard "look" shortern then thay are. This is the same reason we are not flying biplanes today and one reason twin rigged boats nerver will performe either. //Calle |
#92
| Upwind performance-conclusion So we can feel confident that the lift vs drag is the primary issue in the original question on pointing? And mostly the Hydro end of it in this case? I just want to make sure I have it right. Emphasis on primary...For those of us who are a little less advanced. Thanks. ![]() |
#93
| Hate to be the proverbial wooden nickel, yet I would like to resolve the above issue regarding maximizing L/D for optimum windward performance and seek clarification. Is indeed max L/D our target? Quote:
Though Max L/D appears to be a simpler resolution! Quote:
#94
One factor that enters into this is the hydrodynamic lift from the hull depends on the lift from the rig. The L/D of the hull is limited by the amount of lift demanded by the rig. In offwind sailing, the L/D of the hull is very low because it has drag but is not required to produce much lift. This isn't a fault of the hull design - it follows from the sail trim and point of sail. In upwind sailing, if the maximum aerodynamic L/D is below stall, it may pay to trim the rig for maximum lift instead of maximum L/D, even though the aerodynamic drag angle will increase. The added lift can improve the hull's L/D and reduce the hydrodynamic drag angle more than the loss in the aerodynamic drag angle, and improve performance. In general, for the kinds of boats we're talking about, the windage is so high that the rig will stall before it reaches maximum L/D. So there's benefit in improving the maximum lift as well as the L/D of the rig alone. But the really big gain may come from reducing windage.
#95
| Does that statement apply to the keel as well? |
| Heavy sailboats : Can they point ? | xarax | Sailboats | 100 | 06-24-2005 09:36 PM |
| Can anyone give me information of modifying my hull for better performance? | lovingthekeys | Boat Design | 1 | 12-22-2004 02:36 PM |
| Novice - Boat wake / performance question. | jav | Powerboats | 10 | 08-09-2004 04:07 PM |
| Yacht performance comparison | Wardi | Sailboats | 7 | 05-23-2004 08:43 AM |
| HELP ! Canting keel for 28ft performance daysailer | Guest Jan | Boat Design | 10 | 12-03-2003 11:07 AM |
