#106
| Thanks Brian, That was a nice read... One question for me is relating to the stresses on the mast of a "hitch-hiker rig" - does the removal of the main reduce the loads?
__________________ building commenced 23April2009 - - http://boboramdesign.wordpress.com/39-c/ chatter on my build progress . . . http://www.boatdesign.net/forums/boa...-new-post.html |
#107
| Prout Rig sailors The Prout catamaran rig had considerable influence on me when I first began to develop my aftmast concept. So it was interesting to have just this evening run across a forum discussion group that includes a number of Prout owners who seem to be quite happy with their aftmast rigs for cruising, albeit not raked rigs. http://www.cruisersforum.com/forums/...-rig-3362.html |
#108
| Sailing off Mooring or Dock without engine assistance ...this subject came up here...and I felt it better to add my response here, as it concerns this rig concept Quote:
You know I can still imagine sailing a big 65-foot catamaran with this rig right off the mooring, and back to the mooring, without the engine, by myself, with so little effort that I might take it out having only a few spare hours to kill, or a day sail. I could simply unfurl my 'central mainstaysail' and back it over if neccesary to go backwards or fall off the wind...all very tame and controllable in and around a crowded harbor area. And I would rig mine with tiller steering rather than a wheel and get a really good balanced helm. I would be less concerned with reefing by myself if the wind were to really come up. If I were short-handed at sea, I would have many of the benefits of a ketch rig, without the necessity of slab reefing the main and mizzen sails of the traditional ketch rig. And I wouldn't have to uncover any sails, nor recover them when I returned to port....I could be at the club's bar while everyone else was putting their boats to bed. Interestingly the 290' Maltese Falcon with its modern square-rigged "Dynarig" has manage to sail off, and back to its mooring. |
#109
| Brian, "Cornish fishermen are rigging their boats for sails, as we report today, is one of the few (but possibly the first of many) positive results to arise from the rocketing price of fuel." http://www.telegraph.co.uk/opinion/m.../20/dl2003.xml Perry
__________________ Whilst entitled to your own opinion, you are not entitled to your own facts! |
#110
| the Ketch Rigged Cat ...this comes from another forum, and I post it here to make reference to it in the near future Quote:
Here is the gentleman & firm I want involved in the final stress analysis of this rig concept, Chris Mitchell of AES. I'm currently in discussions with him about this consultation work, and hoping to have a definitive client willing to pick up part of that expense. **(have a look at this paper, Design Notes, and particularly under "Cruising Catamaran Rigs", ) (while you are in this paper have a look at "Geometry:Cap Shroud/Chainplate". I will reference that in a minute) Please understand that there are many designers and naval architects that could not do adequate justice to rigging analysis that falls outside the 'norms'. Free-standing mast systems are another of these 'outside-the-norm' design projects that need a specialist involved. Eric Sponberg is another choice of mine to evaluate unusual rig designs as he has had to do on many free-standing projects before. I'm the concept guy, no longer an engineering specialist. Having said that let me point out a couple of critical items I see in my aftmast rig design: 1) Masthead Loading: Some folks have noted that I would not be able to maintain a reasonable tight forestay as a result of the mast leaning forward. But look closely at my masthead. The single backstay at that point is making a greater angle with the mast than many traditional sloop rigs....more reward pulling advantage...about 27 degree 'back-capstay' angle...pretty good. 2) Hounds Loading: Here is were I will experience some problems. As drawn at present There is only a 10 degree angle between the lower backstay and the mast....thus significantly higher compression loads to the mast. But if I attach this backstay to the front of the mast and run it to the very sterns of the vessel I get a 15 degree angle...much better. And if I chose a 6 degree rake for the mast rather than the 10 degrees shown, things change again...likely for the better. This is a portion of the 'stress mapping' I am seeking, and this is Chris' forte. 3) Capshroud Loading: As Chris points out in his paper you neither want too small a capshroud angle (big compression loads), nor too big a capshroud angle. But why not bigger....because on a traditional rig with a mainsail the head of the mainsail bends off to leeward and tries to twist the top of the mast excessively. I don't have this 'head-of-mainsail' load as I have no mainsail...so I might well make use of very wide spreaders and big capshroud angles to lessen the significant compression loads to the mast imparted by the stability loading Last edited by brian eiland : 08-22-2008 at 11:58 PM. |
#111
| Aft of Amidships Mast Interesting multihull site just brought to my attention by Sailing Anarchy. As I paged thru the site, this feature jumped out at me, "Several features give the M61 the most powerful and versatile rig possible for this sized yacht: a racing standard all-carbon rig, with an aft-of-amidships raked wing mast" Moxie Yachts http://www.moxieyachts.com/ Click on their 'M61' model and then under 'Innovations', have a look at the 'Rig' ...(BTW it's not raked fwd, and it's not a mastheaded rig) |
#112
| Brian, Here is a site with a great explanation of the development of eastern coastal sailing vessels from log canoes to skipjacks with their aft raked masts. http://www.mariner.org/chesapeakebay...an/wat002.html Best regards, Perry
#113
| Wiebel Sailing craft Here's an interesting variation of a aftmast rigged sailing craft that was bought to my attention some months ago, but I only recently found it in a stack of papers I've ignored for quite awhile. http://www.wiebel-sailing.com/index.html ..and here some other forum discussions of that craft New Speed Sailing Contender |
#114
| 55 ft Cat sail plan Well, it has taken a long time, but my new boat design is nearly complete. I engaged Richard Woods as my consultant in the design of the hull. He has patiently guided me while I designed the sailing rig and the accommodation and he has been exceptionally professional in his approach to the hull design. Brian, you can see a lot of your thinking in this rig with a mixture of other ideas of mine and from pictures. I hope you will give me your blessing, but please feel free to comment on any aspect of it. Here are the drawing of the rig. While I know that they will not suit every taste, they are just what I want: a mainless rig that is easy to handle single handed and that I can safely lower in a minute to go under bridges. The two fore sails will be on 'Stay Furlers', since the forestay are Dianeema rope, they can be bent over the trampoline when I lower the mast. They do not reef, so they will be either in or out according to the wind. The mizzen is on a conventional Furler that can be reefed. Lastly there is a storm sail that can be hanked in the unfortunate case I get caught in a gale. There you go, I reopen the subject for all to participate in the discussion...
__________________ Keep smiling Stefano |
#115
| Eh Spif, It looks very nice. I like the width, although some think it just takes you longer to get to the head. You can't go too wide either else you won't fit in any harbour ![]() I like your sail setup as well. For your purpose I can certainly see why you have it as it is. That 128m^2 main sail is going to be a nice and powerfull bugger, better add a proper grab rail and some gloves... or get a decent winch. You may want to add a detachable boom on it's foot, especially for when you run.
__________________ Regards Fanie |
#116
| Thanks Fanie, The actual size of the sails might still change a little, but the foremost sail will be a Yankee of ~120mq, the Genoa is ~60, while the Mizzen ~40. I don't think i will keep all the 220mq up in more that ~10kn of true wind. Then I will furl the Genoa or the Yankee depending of what the wind is doing. At 25kn, perhaps just the Genoa and furl the mizzen, then swap and just sail with the mizzen. With furlers it is going to be easy to reduce sail even going downwind!
#117
| aft mast - dream or reality? I see Spiv's version of aft mast rather practical. Mast is close to vertical, frame stucture for transverse stiffness. It will be good to test it, but I do not expect excellent windward performance. Actually I do not belive in aft mast rig so much advertised by Brian - it has never been built and never proved working. Unfortunately some people are mislead by this nice but unproven concept. I have serious doubts if aft mast rigged boat is capable to tack due to sail area distribution. Aslo there are serious concerns about windward performance. Anyway soon we will have chance to test it on one of our designed cats. |
#118
you are right that Brian's mast has not been tested yet, however the concept is aerodynamically excellent. You are mistaken if you say that aft masts have not been built as we already know of several, I repost their pics here. I have spoken to the owner of boat No3 and he very happy with his rig and assures me that the she goes to windward exceptionally well. My personal experience is that i could tack my 42' cat without problem when sailing with jib only. Anyway, who wants to beat to windward when cruising???
#119
| On a smaller scale, haven't you guys seen what I did with the little trimaran I built ? Aft mast... I've slowly started on the 10m cat and have decided to do a 8m to 9m one as well, both with double masts and sails.
#120
| I never said 'aft mast has never been built'. There are few boats built most known is 'Prout rig'. I just stated that Brian's aft mast rig has never been built and tested. It is aerodynamicaly excellent (if we neglect slack of forestay ) but structurally weak, and mainsail does not seem practical. |
| Self Righting Rig | Wardi | Sailboats | 14 | 06-29-2005 02:03 PM |
| Reactive rigs | yokebutt | Sailboats | 1 | 04-07-2005 05:46 AM |
| Alternative sail rigs | bfrowe | Sailboats | 3 | 01-17-2005 09:49 AM |
| Cruising Sail Rigs | brian eiland | Sailboats | 0 | 07-31-2004 10:55 AM |
| Big Cat, alt CB's & sail rigs | brian eiland | Boat Design | 0 | 10-01-2003 11:41 AM |
