Corley
epoxy coated
- Joined
- Oct 21, 2009
- Posts
- 3,781
- Reaction score
- 199
- Location
- Melbourne, Australia
I agree that its not a performance idea, but a cruising one. That, done well could well be faster for cruising reasons. The main reason being that cruisers often sail under headsails only because they could not be bothered raising their large mainsails. They might not raise them because they are single handing and have a large boat, or they are only sailing a shorter distance where its just not worth the time and effort to raise the main.
The "moot point" about not needing the main anyway when cruising is not moot at all. Passage speed is important. When the main is smaller and the headsails are larger, you will be going faster under headsails alone. BUT, the important part is the mainsail (I am saying still use a decent size and high performance main) is that bit smaller so is easier to raise anyway. So for cruising reasons I think it could be faster, even if for racing reasons its not.
I'm just using my own boat as an example, 70m2 main. 40m2 genoa. And a 70m2 screecher which is a fragile setup on a 2.5m pole and endless line furler (pic in this thread). Its not to be left up in strong winds (even furled) and certainly not for use single handed. Setting up is a PITA with the pole etc, and you would want a decent helmsman to get it down if the **** hit the fan rather than an auto pilot.
The main is a PITA to raise and pack up alone. I think the boat would still have very good performance with say a 55m2 high aspect square top main (same height as now), and 35m2 heavy jib for windward work. I think this setup would be as fast or faster to windward than what I have now once the wind got to the point where I would have to reef my current setup (which happens fairly quickly) thanks to the higher aspect ratio. Sure in lighter winds, it will have less power.
However, I now also have room for a larger headsail (say 70m2) on a real furler (single handed safe) so the power will be the same or even greater than before, but with this up it might not point quite as high (not as good for racing). Downwind, speed will be comparable, as sail area will be similar (the cutter rig means I can use both headsails), but it will be much faster with headsails only as the headsail area will be much larger.
So its not fastest for racing, but for cruising its probably faster unless you cruise your boat like a race boat.
I would just like to add, I am usually the one flying thier mainsail when everyone else is just using thier jibs (when I'm not alone anyway). Seems a normal affair in Moreton bay for the weekend cruisers to not even bother with unpacking their mainsail bag, even in light winds. For them, the main is a waste.
Fair enough but you have already answered your own question just use a smaller main on the existing mast. The alternative is to have a smaller rig but then your passage average speed will take a hit due to poor performance in light conditions.
I'm not trying to push any particular stance on the issue and as I noted there are a lot of good reasons to break up sails into smaller areas and your main being a PITA to raise and deal with could be as good a reason as any.
Sailing performance from a certain point of view could be defined as having the maximum amount of sail that can be easily dealt with for whoever owns the boat. Sails that are zipped away in their bag are not helping performance.
