I don't think these super maxi racing yachts have a "aft mast" rig in the same way Brian describes them. Look at Wild Oats. They went to the trouble of moving the mast and keel back so they would have more bow. Well the actual way they did it was to cut the stern off then make a whole new bow. The reason they did this (its in all the articles), and I assume Comanche was already built like this, is so they can carry massive sail areas downwind with out nose diving when ocean racing.
They have what is a usual boat and rig but with a lot of extra buoyancy forward. The same thing with many racing multihulls. Its all to keep the bows up. Now when you have a long bow sticking out forward on a racing boat of course you are going to run your lighter sails all the way to the front. Look at the amount of inner foresails they carry!
Wild Oats still wouldn't be mast aft even after the mods, but they obviously thought moving the mast and keel back was worth this multi million dollar modification.
....I still would never want a main bigger than on my boat (43 foot performance cruising cat) which is 70m2. Its hard to raise as its. I think 55m2 would be a more manageable size to raise. Once its up, its fine. But the sheer size is a little daunting downwind in strong wind, and roached mainsails on cats are always a PITA downwind on cats thanks to shrouds.
I think a more aft mounted mast would still be great even for a performance cat like mine. The mast would be the same height. The main would have a shorter boom and then have an aggressive squaretop. Over all it would probably loose about 30% area (so become 50m2) but be higher aspect (with rotating mast) so it should still have great windward performance in combination with a larger headsail which would also be 55m2 up from 40. This would probably move all the effort from raising the main to sheeting in huge headsails though. Deck gear would need to made very strong and maybe even electric sheet winches. There would be at least 2 permanent head sails and the screecher/spin would be removable on a pole.
I have been single handing lately and just using the 40m2 headsail. For shorter trips its probably not much slower than using the main too when you include raising and lowering it then packing everything away. Having larger headsails are obviously a benefit here. The main issue I see is it seems hard to put the mast in a nice spot so you still have a decent sized main. Its either before the cabin on the main bulkhead, or waaaay back on the back of the cabin top, which seems to far back for what I would like. Not that I am ever going to change anything on my boat, but one day when I finally build one...
