brian eiland
- Joined
- Jun 3, 2002
- Posts
- 5,565
- Reaction score
- 323
- Location
- St Augustine Fl, Thailand
Storm Sail Configurations
What brought this to mind was the recent de-masting of the new Gunboat 55 in storm conditions off the mid-Atlantic coast a few weeks ago. And any possible misconceptions that I would suggest using the rolled up foresails on my rig as storm sails.
So while searching around the internet for articles on very modern-day sail materials to be utilized with roller-furling applications I came across this article that I would submit as the proper manner to address handling a storm sail configuration with my 'staysail-cutter-ketch' rig.
http://www.sailmagazine.com/boatworks/storm-sails
excerpt said:One solution is the Gale Sail, which has a sleeve that wraps around the furled-up genoa and is attached with large piston hanks, which are easy to manage with cold fingers. As the sail is hoisted, the Dacron sleeve of the Gale Sail slides over the Dacron fabric of the headsail with surprisingly little friction. If you have ever stepped on a flaked Dacron sail, you know how slippery Dacron-on-Dacron can be. You can hoist the Gale Sail using a spare genoa or spinnaker halyard. Once it is set, there is very little chafe as there is no point loading anywhere along the luff of the sail. The sleeve spreads the load across the entire length of the luff of the storm jib. With the tack pennant premeasured, the sheeting position will be in the correct place as soon as the sail is hoisted.
Ideally, a storm jib should be set on its own stay well abaft the bow, so that the sailplan’s center of effort is kept close to the middle of the boat. The Gale Sail is set off the forestay, which is not a safe and convenient place to attach the sail—one of the drawbacks of the system. Even so, a purpose-built storm jib set securely over the furled headsail is adequate for gale force conditions—providing it is set up before conditions deteriorate too much. It would be no fun trying to rig such a sail while hanging onto a bucking bow pulpit.
The Bluewater Cruiser
The cutter, which has a permanent inner forestay, is a popular rig for offshore sailing. This stay can be used for a heavy-weather staysail as well as a storm jib. Sails set on the inner forestay are usually clipped on with hanks, so it’s not a lot of work to lower and lash the staysail and then hoist a storm jib. The cruising couple on the 50-foot bluewater cruiser in this example do have a permanent inner forestay, and they hank their storm jib onto that stay. The tack pennant keeps the sail up off the deck, which allows waves to pass underneath and also leaves room for the working staysail to remain attached to the stay and stowed in its own bag.
