  #136
Old 05-17-2009, 11:26 PM
brian eiland's Avatar
Rep: 1503 Posts: 2,648
Originally Posted by masalai View Post
It is not, it is sailing downwind faster than the wind
Not sure of what you speak?
This tri in the photo is most likely not sailing downwind judging from most indicators, particularly the closeness of that headsail sheeting and the small amount of twist in that fat-headed main
  #137
Old 05-17-2009, 11:31 PM
Originally Posted by Alik View Post
The geometric CLR/CE relation is basic thing and it seems correct from Your sketch. To be accurate, this is simplified repersentation that works only for proven rigs. I mean that CE of sails will move during tacking motion of boat, and this will seriousely effect tacking performance.
Yes, and I stuck to the conventional method of centers of the areas just as a conventional rig. I don't claim my individual sails to 'different' from ordinary 'proven' sails.
  #138
Old 05-17-2009, 11:35 PM
Alik's Avatar
Alik Alik is online now
Rep: 1020 Posts: 1,893
The aerodynamic CE of sail is not at its geometric center.
  #139
Old 05-17-2009, 11:38 PM
..I have serious doubts if aft mast rigged boat is capable to tack due to sail area distribution.
I will have similar problems tacking that an ordinary cutter rigged vessel will have....getting that genoa around the 'babystay'.
Note that both my mizzen and staysail (mainstaysail) are both self-tacking. The genoa is probably best left alone (allowed to backwind against the staysail) until the tack is completed, and then hauled around....somewhat std operating procedure in cruising vessels with a big headsail.
  #140
Old 05-17-2009, 11:42 PM
I think we all realize that...it is usually forward of the geometric center. But MOST designers for YEARS have continued to use this geometric center rule to happy results.
  #141
Old 05-17-2009, 11:45 PM
Alik's Avatar
The CE of sails is moving during tacking motion and resulting aerodynamic force will try to push the boat back on original track once genoa is luffed.
On conventional rig, this force is balanced by mainsail, but in Your rig mainsail is rudimentary.
Forget about geometric CE - this does not work in Your case.
  #142
Old 05-17-2009, 11:46 PM
Alik's Avatar
... with conventional rigs where they have plenty of statistical data for this empirical method.
  #143
Old 05-17-2009, 11:47 PM
Manie, it is common knowledge that cats with 'Prout rig' are more difficult to tack compared with conventional rigged cats. This is because of big genoa that blows out and creates yawing momentum that prevents the tacking motion. Small mainsail is not capable to balance the genoa. Of course, it could be different on different boats depending on many other factors.
And I agree with you here.
  #144
Old 05-17-2009, 11:57 PM
On a multihull vessel there are times when guys have had to unsheet the tight mainsail to prevent the vessel from going into irons. The mainsail does not help the tacking situation, but rather may hinder it!!.
Most important in tacking a multhull is to 'turn' the boat into the tack, and not stall it by throwing the rudders over to quickly. Second it pays to have a nice 'pivot point'. For that reason I MUCH PREFER daggerboards or centerboards to long shallow keels.
Get the bow just thru the wind, and that genoa will immediately backwind and push the vessel thru the tack.
  #145
Old 05-18-2009, 12:09 AM
Brian, You have to put big disclaimer on Your website saying that these concepts have never been built.
That is the first thing I say to a person who is inquiring to my rig....and it is likely the reason it has been so hard to attract clients for this rig. And when I tell them it needs some good engineering work on the final staying arrangement(s) most sailors aren't willing to spend for that extra analysis.
I don't have any doubts as to the performance of this rig. I do have serious concerns about rigging it properly and substantially. And I have not tried to hide this from potential clients. See "Backstay Tensions" in posting #98 above.
  #146
Old 05-18-2009, 12:37 AM
Alik's Avatar
This is guesswork form Your side unless supported by sea trials.
  #147
Old 05-18-2009, 02:15 AM
A-Frame Rig on Kolika
Originally Posted by Spiv View Post
...Here are the drawing of the rig.
While I know that they will not suit every taste, they are just what I want: a mainless rig that is easy to handle single handed and that I can safely lower in a minute to go under bridges.
The two fore sails will be on 'Stay Furlers', since the forestay are Dianeema rope, they can be bent over the trampoline when I lower the mast. They do not reef, so they will be either in or out according to the wind.
The mizzen is on a conventional Furler that can be reefed.
Lastly there is a storm sail that can be hanked in the unfortunate case I get caught in a gale.
There you go, I reopen the subject for all to participate in the discussion...
Did you see this website Stefano...lots of photos and a write up on an A-frame masted vessel:
http://www.sail-works.com/KOLIKA/index.html
  #148
Old 05-18-2009, 02:22 AM
This is NOT guesswork, it comes from multiple years of sailing multihull vessels, both small and big.
Have you ever tried tacking a Hobie 14 catamaran??....mainsail only design, and no 'board' to pivot about.
  #149
Old 05-18-2009, 03:04 AM
Alik's Avatar
Brian, I sailed/raced B-class cat for many years, plus other bigger cats. Besides, I did a Ph.D. on subject of sailing craft manueverability where did computer simulations of tacking motion as part of research, including tank tests and GPS measurements of trajectories.
The things You're taking about is Your guesswork, because they are not supported by engineering calculations and/or sea trials. So we want to see prototype boat with Your rig built and tested before can contunue this discussion.
  #150
Old 05-18-2009, 06:12 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Alik,
The recent trip the Vaal dam with the little trimarang with it's aft mast sail had similar responses from some hardened sailors there.
This one guy told me he saw those aft mast sail setups before... on Kenya lake (the philamons in Africa are years ahead of us) and they can only sail downwind.
So there you go. Aft mast setups come from Kenya, the philamons have been using it for YEARS there and they have trade winds they sail downwind in only.
The dumb f idiot at the Vaal never saw me sail in and out of his marina the three days we were there. The wind blew us out and back in so our timing must have been good coming in and going out.
It was rather a matter of him being very PO because he was trying to catch us in his big mono, and he never even came close. Beat him to wind too. He must have been an inexperienced sailor.
If I was you I'd stick with what you was tought in the phd. This sailing setup will not work for you. It requires a bit different thinking and as I said before there is a few tricks to it you miss.
Now you know why nobody sails them
Regards
Fanie
Water ! Just gimme water !
Self Righting Rig Wardi Sailboats 14 06-29-2005 02:03 PM
Reactive rigs yokebutt Sailboats 1 04-07-2005 05:46 AM
Alternative sail rigs bfrowe Sailboats 3 01-17-2005 09:49 AM
Cruising Sail Rigs brian eiland Sailboats 0 07-31-2004 10:55 AM
Big Cat, alt CB's & sail rigs brian eiland Boat Design 0 10-01-2003 11:41 AM
